Tim & Dave Kinghorn
Hi Casey,
Welcome to the "Eureka, I've Found Water" club.
On our 23' Venture, the bulkhead extends to the hull bottom and considering the volume of water that was under the cabin sole, this seam appears to be relatively tight. On the cockpit side, the injected foam made somewhat of a seal against the cabin bulkhead (it was wet on the bottom, but this could have been leakage from the seam along the base of the bulkhead where it meets the cockpit deck). Inside the cabin, it appears to be tight as seen through the inspection hole. When we found water under the cabin sole in the forward inspection hole, we knew it wasn't draining to the aft inspection holes between the tanks as this area was dry and the bow was elevated for drainage. This lead to the additional inspection plates inside and outside the cabin door (see pictures in photo album). We had hoped, as some have found, that it was clear under the cabin and cockpit decks from bow to stern. But it was not. Additionally, as the water pushed its way up through the joint in the cabin sole (3" from the door) and under the cabinet and dinette, it would seem if there was an opening under the bulkhead, it would have pushed water into the aft cockpit void (We're going to fiberglass this seam).
As to possible sources, the most likely suspect is the chain locker. On our boat, there was a considerable gap which took an effort to fill. Others with water intrusion have found it stopped when the locker was properly sealed.
A second possible suspect is the fresh water lines. We're going to install lockers under the forward berth (See Sea-Daisey Photo album). This will allow a close inspection of the lines when filling and when under pressure as some have found leaks here.
A third possible source is the bow-eye to which you attach the winch. On our boat, this eye has double shank and has pulled slightly away from the prow (about 1/8") at the top. Inside the chain locker, one of the two shanks is accessible and has an eye nut on it to which the anchor rode is attached. But, the second shank is under the bottom of the chain locker and will take some effort to get to it. This can let in a lot of water. See "Safety Concern" in the Hull, Deck and Fittings forum by Amy and Karl on C-Daisy.
A fourth is the seam along the bulkhead in the aft-cockpit. We're going to fiberglass this seam. We have also resealed the tank bolts as suggested by Dr. Bob with the Marine-Tex putty, and additionally have used an epoxy sealant around the sides of the cockpit and across the back of the inside of the stern. We got a gallon from the Defender Catalog for about $63. Tinted white, it looks great. However, we didn't see any visible cracks, but we are going to pressurize these voids and check for leaks with soapy suds as Pandy Girl did.
Finally, using a hose we plan to check all possible outside leaks into the boat from through bolts to through hull fittings to the Wallis exhaust.
If nothing else, we've learned a lot about our boat and quality boat construction and proper fittings and have gotten great input from folks like kmcclish from Southern Cal. This site is well worth donating a few bucks to considering all the information and great ideas from folks with similar boats.
Tim and Dave Kinghorn
P.S. I tried to delete the first message, but I was unable to clear it. I wasn't trying to be cute, but I'm still trying to figure out how to use this site!
