No Worries
- Joined
- Oct 10, 2007
- Messages
- 36
- Reaction score
- 0
- C Dory Year
- 2006
- C Dory Model
- 23 Venture
- Vessel Name
- No Worries
Yeh I have read through the post and am in the process of getting a game plan in place. I think I have a good plan now. I really appreciate all the help. I think I will start with the inspection plates just to get an idea of what I am facing..... Thanks mucho Doug...
PS any good ideas for ways to dry out the hull once the inspection plates are in place?
Tim & Dave Kinghorn":2zfq0i6x said:Hi Doug,
If you the time, read all 11 pages on this thread--especially see Ross on p. 4 & 5 of Pacific Wanderer, Oldgrowth on p.5 of c-voyager, and Casey on p. 10.
You could take out one of the lag bolts holding down the gas tanks amidships (by the sump) and check for water under the cockpit deck by sticking a rolled up paper towel down the hole.
At a minimum, a 4" inspection port in the forward berth area, under the porta-potty and one aft between the tanks would allow you to determine whether you have water under either the cockpit deck or the cabin sole. In cutting the aft inspection port, be aware that some c.c. have a spar down the center between the tanks.
If you have water coming up in the cockpit, you most likely have water under the deck and probably under the cabin sole. The inspection ports will allow you to remove any water, dry out the area, and keep a check on any future water intrusions.
A number of us have gone through this drill (see Ross), and it has solved most of the water intrusion problems that have bedeviled us.
Happy boating!
Tim & Dave
