Well-known member
- Joined
- Oct 27, 2012
- Messages
- 3,789
- Reaction score
- 111
- C Dory Year
- 2008
- C Dory Model
- 22 Cruiser
- Vessel Name
- SoBELLE
thataway":2lxp741a said:Not sure, but to me it looks although the basic unit is the same with 3 options, that you have to choose between chemical, poop and go, or composting? You buy the basic unit and then $62? for the attatchment for bag or chemical..maybe none for the compost? You still have to cart the urine off every day or so? No ventilation, so anaerobic composting--maybe more odor? Uses wood chips, vs the coconut coir or peat moss etc. that most of the aerobic units use. Any reviews of use? No. It will not be available until July,
The company has other products which have been good, such as the hot water shower.
ssobol":1fkbrzrh said:thataway":1fkbrzrh said:Not sure, but to me it looks although the basic unit is the same with 3 options, that you have to choose between chemical, poop and go, or composting? You buy the basic unit and then $62? for the attatchment for bag or chemical..maybe none for the compost? You still have to cart the urine off every day or so? No ventilation, so anaerobic composting--maybe more odor? Uses wood chips, vs the coconut coir or peat moss etc. that most of the aerobic units use. Any reviews of use? No. It will not be available until July,
Way I read it is that you choose the configuration you want for one price. If you want a different or additional cassette, you buy that extra. 'Bout 1/4 the price of an Air Head or Natures Head. Doesn't seem to require a fan. Might not work as well in composting configuration though.
DaveInRI":19t37stv said:Does anyone have pictures of a true composting head on a 22? ...
All of the "composting" toilets on the market are not true composting toilets. A more appropriate name would be desiccating toilets.
Composting of organic material usually requires the use of bacteria and the generation of a fair amount of heat.
DaveInRI":176o8guj said:Hi, Donald. Where do you store it underway? Does it fit under the filler cushion, also? Thank you.
