We also needed to re-bed the hand rails on the top of the cabin. There was a slight leakage of water during heavy rains. We found out why--the bedding was not adherent to the SS railing. We pulled the rail:
Below is a "shower curtain rod" holding up the electronics shelf when we pulled the bolts to rebed the hand rail with 4000.
Note that we moved one radio and put a second radio (with AIS and hailer) to the bottom of the electronics shelf, and epoxied blocks of wood to the forward pilot house so that we could mount the stereo speakers (were loose on the shelves).
We also like the "hand rails" on the inside; trying to get factory rails did not seem like an option, so we are trying: rope. I used SS clamps with rubber insert the same diameter as the rope and put a right eye splice on each end, and then served it with self amalgamating tape, and an overhand knot in the center. We may have to put in epoxy blocks to keep the clamps from moving. This is an experiment:
In the back ground, hooks for jackets and hats, plus the wire to a cockpit LED "spreader light" on the outside and a 3 red LED night light on the inside. We have added an extra light directly over the helm--LED 4 red and 4 white.
Projects left: The kicker bracket (dinghy motor), and two Starboard tables which will mount just inboard of the lazarette hatches, on flush Magna mounts (photos to come in the next day or so). We have a Wilson Marine dual band cell phone antenna--to go with our Wilson cell phone amp we use in the truck and RV, as well as a 2 meter ham antenna on the opposite hand rail aft. Both will ratchet down for travel.
We have also added a Hyperjuice 150 watt external battery for the MacBook Air and I pad, I phones--extra capacity, and the ability to charge all of these devices from the 12 volt system (including the MacBook Air.). That along with the Cell phone antenna and amp will extend our range to keep in touch.
Also we put in the BEP VSR to combine the batteries:
The bus bar for the Link lite will be next to this switch also--hopefully avoiding any fine wiring going directly to the batteries-instead going to the BEP VSR and the common ground point all in this area of the Stb lazarette.
We also added a second bilge pump in the aft sump (standard is the one just forward of the aft cabin bulkhead.)
Now a night on the hook to check out all systems and start to load up and head out West!
