Video of cruise & mishap in Fords Terror Inlet, Alaska
Jay,
Thank you for such a delightful--and tragic ending--video clip. Beatifully done!
Marie and I took "Thataway" our Cal 46 into Ford's terror twice. It is one of our favorite places in Alaska. Since the Cal 46 is a 6 to 8 knot boat, with 5 1/2 foot draft, we timed our arrival at the entrance to be just before high slack. Well, there is no slack! We launched the RIB, and Marie handled the Cal, when I ran thru the entrance in the RIB--I quickly realized that there was no slack--it was already turning to ebb inside, although it was still flood at the outside, so I radioed Marie to start thru--and we had the RIB set up so we could put it aboard when underway with an electric winch over the transom. No problem getting thru, but there were two Kayakers who tried to make it, but could not make headway against the ebb half way thru and had to line the kayaks thru--complete with bear on the bank. We had gone past them, not realizing the difficulty they would face. Later we took the RIB up to the rapids, so see how much force and speed there was at full flood. We had a 12 1/2 foot Avon with a 25 hp--could do about 32 knots.
We could not make head way at a certain point against the flood--part was the wave pattern and part was the volicty of the current. I guessed that the full flood velocity was over 20 knots.
For those who have not been in Ford's Terror, it is a fjord with an entrance only about 100 feet wide and several hundred yards long of turbulant water. At low water, the depth is only about 2 1/2 feet and at high water that plus the tide--in the mid to high 20's deep. The fjord is about 30 miles long, with two arms at its extreme. One is steep and the other more gentle and we took the dinghy several more miles up the river at high water. We climbed the face near the waterfall--and hiked the back country up there. The walls of the fjord can be as muc as 1500 feet high and are sheer. We anchored in 100 feet of water just below the water fall--and the current kept the boat off of the banks.
The first time we spent 3 days in the fjord--and saw one charter boat and two kaykers--the second time we spent 7 days in the fjord and saw no other boats or people. Even ham radio was difficult to get signals out because of the high walls. It is an extremely isolated place.
We think it is one of the highlights of an Alaskian cruise--about 50 Miles S. of Juneau and 90 miles N. of Petersburg on Endocott Arm.
Ford's Terror is named after the naval crew member, John Ford, who, in 1889, rowed a dinghy into the narrow entrance of the fjord at slack tide. The tide began to rise, forcing its way through the bottleneck entrance into the fjord, and Ford was trapped in the turbulent currents for the next "terrifying" six hours. It was said that he could not talk for several days after the experience.
Brent:
Thanks for the link, We also use a Mac.
Jay:
I appreciate the post. Fascinating. We were in Tracy Arm this summer but did not go to Ford Terror.
What would you do differently?
Rick
All,
Thanks for the appreciative comments. Was a struggle to make and post this video. Your comments definitely made it worthwhile.
Pete (Adeline), Appreciate what you said, but I don't think its courage that takes us to unknown waters. Its what we live for. To do anything else would be only to exist. The following poem by Jack London, aptly describes our philosophy of life.
I would rather be ashes than dust
I would rather
that my spark should burn out in a brilliant blaze
than it should be stifled by dryrot.
I would rather be a superb meteor,
every atom of me in magnificent glow,
than a sleepy and permanent plant,
The proper function of man is to live, not to exist.
I shall not wast my days trying to prolong them.
I shall use my time.
I apologize if this sounds preachy. I know you meant courage as a complement.
The c-dory is fantastic, but if it wasn't often used to take us to explore these kind of places we would not be boating. Up until I was 51 I explored mostly by myself, on foot, horseback and canoe the most remote areas I could afford to go. Jo-Lee and our boys would go with me in the places and times they could. Now with the c-dory, Jo-Lee and I can go together in what we think is extreme comfort and explore places just as remote and beautiful as anywhere I have been before.
Salmon Slayer and Bob (Thataway), good to hear from others who have been there and experienced what this exceptional place has to offer those who are willing to accept the risk of going where you are entirely on your own. Bob, I especially enjoyed your description of the time spent there by you and Marie. Would love to hike up and look down and out where you and Marie did. Hopefully that will happen in the future.
Rick (Flyer), so what would I do differently now? Complacency is never good and I imagine its the root cause of many accidents. We did see the rapids ahead and were expecting an exciting ride. What we didn't expect was the 1st big hole and drop off. From up stream looking down the rapids appeared to be easily navigated. As the video showed the hole could not be seen until it was to late to do anything but work the throttles and steer, which I did. I cut the power just before and during the drop and when the bow dug in I gave power to it get it up and out and lower the stern. When coming out of the 1st hole cut power back then used just enough to maintain steerage through the rest of the rapids. After taking inventory of losses we turned around and went back up the rapids to see if we could look into the big hole. Couldn't make it that far... Just like looking down current could only see the rapid tops. This was actually the 1st real white water Jo-Lee or I had ever run in any boat. Bob, have you seen the rapids at a low ebb tide?
On the east side of the outer bay there is a channel that leads to a temporary anchorage and a place where I think I could land a dingy in the future to see just what these rapids look like at a low ebb tide. This is one of the things I would like to check out this spring.
So again, what would I now do differently? Hopefully be more cautious and thoroughly check out area before going through. Generally the 1st mate makes sure I do it that way.
Kieth (c-pup), 0 damage to props, lower unit and boat. We do have a survival kit containing sat phone, small gps and bear protection among other things. Also an evacuation plan, that includes what Jo-Lee and I will do if disaster does strike.
Another Mac user here who appreciates the link for the download... even though I knew what was coming by reading the other posts, it still made my butt pucker. We've run white water on the Snake River before... in a raft, not a C-Dory! Some of those holes look like jumping over the side of a building.
Sorry to hear you lost some stuff, but so glad you two came out of it in one piece. Great adventure! Also, I really appreciated that poem from Jack London.
Thanks for the great post.
Wow !!! Sue and I were watching the clip and even though I kinda knew what was coming it was like a horror show when ya dove in... Yeow !!
You guys really impressed me with your storys and pictures of your travels when we were at Lake Powell....Ya did it again...
Glad you diden't get hurt... or worse..
Joel
SEA3PO
Jay & Jolee – You two have the right philosophy to life.
I am not the type of person to read poems but the one you quoted is perfect for me. I will probably have to steal it. I want to do and experience as much as I can while I am here.
If you ever make it to the Northwest please let me know. It would be a pleasure to meet the two of you.
Nancy H":2ewn2vrh said:
What to do differently?
Close and lock the front window and hatch!! And close and latch the side windows! :wink
Nancy H,
You betcha!!! Still wondering how I missed that. I'll guarantee you, that front window gets sealed up now at the very least sign of disturbed water ahead. All the damage we suffered was from salt water coming through the front window and ruining electronic equipment. Computer and cameras, eventually even the sonar connections corroded and I broke the pins trying to clean, so had to replace. Also if the front window had been closed several difficult days spent at Petersburg, AK, trying to get new computer and software for navigation could have been saved. Ruined video camera prevented the video capturing of wildlife and other scenes we would love to have now.
Dave,
You don't have to steal the poem, we will gladly share. We are not exactly poem people either but to us this poem is beyond extra special and a way to live a life. Our oldest son, Erik was killed while on active duty with the Coast Guard. This was truly the way he lived his short life. He really lived more in 22 years than most will at 80. Jo-Lee came across this poem shortly after his death and it was about the only thing that gave us real comfort.
After I retire in 3 1/2 years we are looking forward to meeting you and many others at different gatherings and elsewhere. Presently I work a 6 day work week and must cram to much into vacations. Have to go back to work to rest.
Both of us had a wonderful time at the Lake Powell Gathering last spring.
Joel (SEA3P0),
We are no match with you in good stories. Break out laughing even now, when thinking about time spent around the campfire listening to you. Appreciate your comments.
That was fun , can we do it again???. Man that was some ride. We run the rivers around here with jet boats while fishing. My friend Alex ran his 16 ft smoker over a hole like that on the sky last year. everone got wet but made it , just had to bail like crazy. He learned and has taught me that you have to aim for the "V"'s between the rocks. thats where the deeper water is. Going up or down just aim for the v's.
Jay,
Yes, the day we went up to see the rapids thru their entire cycle, we arrived at low tide. We stayed for about 5 hours in the area--had to leave the left bank going in for awhile because a brown bear was being territorial. You could anchor and walk along the rapids on the left bank going in to survey the condition of the rapids. I probably have some slides of the various stages of Ford's Terror, we used in our lectures on Alaska. The second year we were in the Terror--there was significant ice in the inlet--and we were a little concerned about transit because of the ice.
Fortunately many of these rapids do have areas where you can be out of the current until the time to go thru. Our plan was to always arrive at rapids of any sort just before high slack water. We would survey the rapid before transversing.
OK, someone tell me what went on, regarding viewing the video. No matter what I did I could not get the original video to download. I tried two different computers (XP and 2000), and both times got the error messages "ClassFactory cannot supply requested class " or "Invalid file." I downloaded the wmv file and it worked well.
Can someone tell me what I should of done? I did copy the URL and past it, etc, etc.
Great video, enjoyed the ending. I think turing the other way and going up to Sayer Glacier would have been more peaceful.
The southern Boris
Sawyer has it moments also. We went up with into the ice pack field with along with a 65 foot wooden Australian Sailboat (sailed all of the way Sydney Australia, to Sitka non stop)--and he got caught in the ice pack as the wind shifted. Took about 12 hours to work his way out.
thataway":27ejmfn3 said:
Jay,
Bob,
If you can find them, and it would't be to difficult, I sure would appreciate you e-mailing those pictures to me.
