Jon - CLou
It's been 5 days now and Ray Marine tech support hasn't got back to me yet, so it's time for the ace in the hole, The C-BRAT site. Geez, what the heck do I need the Factory Tech support for when all you smart guys and gals are right here.
Problem: I have a new Ray Marine DS500 sounder (thanks for the tip Dusty, I love it) and the unit shuts off when starting the engine. The unit shuts off approximately 4 seconds after starting the engine, then re-starts itself right after that and works fine. What would cause this?
This unit replaced my Garmin 250C and is wired the same way the Garmin was. The Garmin sounder didn't have this problem. All my other electronics work fine, GPS, Radar, VHF, CB, AM/FM, etc. All these units, including the new Ray Marine sounder is wired to the same ground bus and hot terminal strip.
The one thing thing I'm not sure of is the RT ground (shield wire) the owner manuel talks about. I only used the red and black off the harness, and did not use any other wire.
Jon
Jon
