Dora~Jean
Active member
- Joined
- Mar 9, 2004
- Messages
- 1,520
- Reaction score
- 1
- C Dory Year
- 2003
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- CD0250171203
- Vessel Name
- Dora~Jean
Spot on Joe! I've been using Bearing Buddys for 30+ yrs, but only since owning my C-Dory have I learned the proper way to refill and check the bearings. I would check them cold at home before leaving, seems thay 'always' needed grease, so I gave each a squirt or two to raise the plate a touch. It would blow that grease out of the inner seal and onto the wheel while traveling to the marina (depending on how far). I went through tubes of grease in a couple of years. Later I found out this method (most likely) destroyed at least 1 of the 4 seals on my last boat, new owner had a bearing failure shortly after taking possession.
Now I only check at rest stops or immediately upon arriving at the marina when they are warm. They rarely require grease, but I always top them off if at the bottom or close to bottom. Seems to work so far (...finding some wood...found it).
The Posi-lube system sounds interesting. And I'd think that repacking the bearings would absolutely be eliminated if the grease is renewed regularly. Does the Posi-lube mfr recommend repacking regularly?
