Regarding octane ratings, I used to have a motor bike which ran on regular gas. I thought I'd up the performance by switching to high octane, and all I did was overheat the air cooled engine to the point that it would seize up until I stopped and let it cool down. Stop, start, stop, start, all the way home. The moral of the story is that higher octane gas really does burn hotter, which is not always that great a deal for the motor.
Years later, someone recommended that I go to a higher octane gas to solve some hesitation/stall problems I was having on my Honda 90(solved another way, but that's another story). I expect this motor also ran hotter until I could burn out the higher octane gas, but I know for sure that it not only continued to hesitate and stall, but now was also very difficult to get started. Which makes sense, since gas formulated for higher compression engines is designed to combust at higher pressures and temperatures, which means that all other things being equal, it will be harder to start in a low compression engine.
So, I'm back to where I was years ago pushing the motor scooter - burning good old regular gas in low compression engines, and concluding that not only are you wasting money burning high test, you're also increasing the likelihood of messing up the motor.
