The camper canvas (Pedersen Canvas, Pensacola, FL)--is done and the photos are up on the album. I discussed with the canvas worker about camper canvas for other Tom Cat 255's. He has made patterns and could make canvas camper backs on a group basis ahead of time--but the boat would have to be brought to Pensacola for fitting and installation. He has both a shop and a dock at his house where the boat could be kept. It would be a good vacation, plus a day to fit the camper canvas for cold winter days!
The top attatchment is fairly standard; vinyl awning rail on the aft ridge of the top. He talked me into the dark green because it comes in Sumbrella plus (totally waterproof, but not fully vinly back as the SeaMark, which has vinly on the inside). The Dark green is very hot right under the canvas--I find that by opening up the front section a little, it will allow plenty of air, cooling off a bit. All of the attatchments to the Bimini are zippers The "door" at each side opens easily for boarding and is about 14" wide. The top is totally free standing--with straight posts at the front and back Tubing was one " SS" with quick release fittings. I will add a second postion "down" for trailering, so that the Bimini is almost on the railing. We went with support on the outside side decks, because I have fishing rod holders, dinghy outboard bracket, the grill and a fishing cutting board/ table which I can leave on the 1 1/4" railings. We used vinyl awning railing on each side--to make a better water proof seal on the foreward side of the boat. The zippers are right against the awning railing, so that they can be left in place all of the time, including when trailering.
The flag pole holder is a standard 45 degree 7/8" SS railing fitting. We put it on the aft transom upper part, which already has a slant of 20 degrees from the vertial--so this gives the flag pole an orientation of 65 degrees--allowing a good "drape" of the flat at rest. This also allows using set screws to hold the flag pole in place in rough weather. The steel 7/8" tubing was cut at a 45 degrees at the end, and a 1/4" thick starboard insert was placed into the holder to prevent damage to the hull gel coat, yet still allow drainage of any water in the holder.
The Garhauer Davit was placed to allow moving the Honda generator from the cockpit floor to a milk crate which is deployed on the transom. There are boards cut which have small depressions cut for the feet of the genset, and has cleates which keep it centered on the milk crate. The auxillary fuel tank will also fit on the swim set on a second milk crate, which is also fitted with a board, and strap to hold it in place. The milk crates due double duty by one holding propane bottles for the grill and extra fuel for the Wallas, and the other for stern anchor rode. A second mounting point will be made on the starboard side, to hoist ice chests and gear aboard the boat. We are considering putting a third point which will allow hoisting the dinghy to the cabin top--or even hoisting the air conditioner on and off. (We both have back problems and are limited to about 25 lbs weight lifting--but can pull on a 6 part block and tackle).
We put the dive ladder clips across the transom, with a safety cable to the clip with a single hole. We have also fabricated the dinghy motor bracket to fit on the railing--motor leg can go outside or inside, depending on how it is mounted. But we are also going to make add some 1/2" bolts to the mount, fitting it into the dive ladder slot, so that the 3.5 HP motor can be used as a slow trolling motor, steered from the cockpit with an extension handle. This should also allow us to run in 15 to 17" of water.
I have put up a few photos of the camper canvas and flag pole etc. Things are finally comming together! Also as we get into the storage--there is a huge amount of room under the bunk--probably get folding chairs etc. I have a folding shovel (for dog) and small hatchet in a box foreward. We also have purchased several "trailer" sand screws, to use in beaches and when in river banks.
