Matt Gurnsey
- Joined
- Nov 11, 2008
- Messages
- 1,532
- Reaction score
- 0
The SMIS gauges are user settable, so it is possible to program in three identical pages.
The gauges can show battery voltage, but it is the voltage present where the gauge is powered from. There is no connection for each battery, so no way that I'm aware of to read each bank. The center gauge could be programmed to show Engine Voltage, which would then be able to show each engine as a seperate page. If the gauges are running off the house bank then the battery voltage could be the house battery, and then each engine's voltage would be what is being out put to the starting batteries.
But- the gauges can be powered by either engine or by the house battery using the optional multi input power node. If the gauges power up when a key switch is turned on, even with the gauge switch on the dash "off", then this power node is used, and battery voltage will be simply whatever the system is seeing.
