Replacing snap fastener
C-Wolfe
Active member
Sep 16, 2020
410
32
Location
Anchorage
2008
255 Tomcat
Callisto
I need to replace a bunch of snap fastener on my camper back. Some of the surface side have been attached with rivet, and I would like to keep those fasten the same way. What would be the best style to use for that application? I’m not sure how easy it would be to remove the screw, and if the opening would be appropriate for a rivet. Just by looking at pictures, I think that the fabric to fabric style would be more appropriate but I haven’t done this before so I would like to hear from more experience folks in here on what they recommend.
While on this subject, I’m planning to order from Sailrite, should I get the all stainless or the brass plated?
I am having a little trouble envisioning which style of snap you are using. Normally the camper back use the "Dot" snap, with female on the fabric and male screwed into the fiberglass of the hull. The "Dot" are less likely to be damaged. The twist lock is most susceptable to damage. The lift the dot with stud into the hull sticks out a bit more. You can get any of those male with either a screw type base, or if the hole is already too big, a threaded machine screw. If the hole is loose for the screw, then use the machine screw type. I am not aware of a pop rivet type of fastener, although you probably could modify a cloth snap (male) to a pop rivet. I usually use the brass snaps, which are plated. They are less likely to rust. However if your boat is left in a salt water slip, then I would consider the SS.
I have to assume that you have no questions about setting the rivets. I have the tools which fit on a. special sent of vise grips, which I have had for over 40 years. I also have a set of manual punches and dies so I can set rivets when on a cruise, as part of my emergney repair kits. As far as pop rivets, I have multiple tools up to and including a hydraulic set. I have a set of cloth punches for cutting the holes. I also have the Sail Rite dies for the "lift the dot" and the turn button fasteners. IF you are just doing a very few, I used a flat plate on an electric soldering iron to burn the small slits, so they don't unravel.
To have stronger canvis sets, have the female side through folded over edge of the canvas, with some stiff material inside of the fold. I use 9 to 10 oz dacron sail cloth, but a small piece of vinyl such as the Weathertite fabric, with PVC vinyl over dacron scrim. (Like the
PVC inflatable dinghy is made of.) will work as well.
In the long run buying one of the backing and cutting blocks will be easist to use and on your punches. There is a plastic and a rubber side. Use the rubber side if there are tabs on the die, which are easily broken. Buying some decent but not the really expensive professional level tools now will make it easier to do canvas work for many years.
IMHO any convo about canvas with snaps MUST include a mention of what I consider the “magic snap tool.” This is the best thing since sliced bread! The quality product linked is made of stainless steel, the cheaper knockoffs are suspect sst or not even sst.
It takes the load off parts of the snaps you don’t want it on (pulls apart from between the socket and stud instead of between cap and the socket) & the other end lets you hold pull/stretch to snap when you have challenges snapping them. (I have no affiliation nor do I get kickbacks from Ironwood Pacific or Amazon.)
*Disregard if you have twist-lock fasteners.
I love mine and I believe it actually extends the life of the fasteners if used religiously. Anyone else using these already?
Thanks for your reply Bob, here’s a couple pictures of my male side “dot” snaps and then the small hole once removed. I might just go with the screw type for most of them.
KC99, I had that exact tool sitting in my cart for quite some time now, you just convince me to finally place the order.
I like to put a little lube on the fasteners peroidically. There are some specific materials: Shurhold Snap-It Lubricant Stick or Star Brite Snap & Zipper Lubricant or just some vasolene or similar material will act as a lubricant and protect the surface. With that much corrosion, I would probably stick with stainess snaps. The "hole" looks as if a screw mount on the male snap should work well.
Wow! A lot of tangents here, but back to the OP's original question, yes you can get Dot fasteners with holes for normally 1/8' diameter pop rivets. If you spend the $ on stainless Dot fasteners and stainless pop rivets you'll likely never do this job again. Now if your holes are a bit wallowed then also get the pop rivet washers and slightly longer pop rivets. Very easy project. Enjoy!
