SGIDave":1yflj7vz said:Hello Colby,
Before you carve up your helm, consider using a RAM mount for the p70R. I used something like this
I mounted the control head to a small board which was mounted to the RAM assembly. You could fix the base to the righthand side of the dash and then adjust it's height to your comfort and viewing angle. With the rotary knob, you can "steer" the boat with just the knob, so locating the unit within easy reach is important.
Fair Winds and Auto pilots,
dave
thataway":2ykiwdlc said:Looks good. Although the Evolution 9 axis sensor is supposed to be auto compensating, and not subject to magnetic fields, I would be sure that, a knife or other ferrous object might throw the sensor off and cause a sudden course change when someone walked by.
