tcr_pnw
- Joined
- Jan 5, 2013
- Messages
- 200
- Reaction score
- 0
- C Dory Year
- 2006
- C Dory Model
- 23 Venture
- Vessel Name
- Sea Star
Good evening everyone! First off I want to thank everybody for their input on my various posts while I search for the perfect boat for our desires. I hope to see you all on the water soon.
My eyes have turned from the 22 Classic to the 23 Venture for various reasons. I found a vessel that I like and I have just had a survey completed on a CC23 Venture that is a 2006 model. I am awaiting the full report but had a good discussion with the surveyor as he went over his notes. His overall impression was "pretty darn good" to quote. A couple areas he addressed, I'm hoping to get some clarification/guidance on.
First, is the transom in the CC23 Venture still plywood? He noticed a couple very faint stress fractures in the gelcoat at the transom near the engine mounts. They are hairline and the owner was not aware, but it is his job to scour for things like it. He did not notice any flex at the transom and believes it to be superficial. Also he did not notice anything out of the ordinary from his percussion soundings. He gave it a factor of 1.5-2 (out of 10) as cause for concern and "repair as needed". He did mention that if the transom was foam, he would much more concerned. What are your thoughts on these minor stress fractures? I will have pics as soon as his report comes in. I apologize I do not have them to post now.
Second, he noticed the fresh water pump "chirp" on and off on occasion during his time aboard and deduced there must be a loss in pressure or an issue with the pressure switch. Should there be a small drip leak in the system, I am curious as to it's design. Not knowing the tank location or how the piping is run, could the water be leaking anywhere with intrusion into the hull? Or is the system designed in a way that a small drip would not have access and compromise hull integrity (I'm assuming construction was still with balsa)? It is not leaking at the faucet but the boat does have a fresh water wash down as well. What are you thoughts on this?
Lastly, the owner is great to work with. As I will be purchasing the boat sight unseen, he is willing to take any additional pictures or answer any other questions. Are there any other quirks or common issues with Ventures made under the Cape Cruiser badge that I should look for in particular to see if this boat is being affected by?
Other than that, everything else was minor or cosmetic. The engines have been well maintained and performed excellently.
Thank you in advance once again for any and all input.
Troy
Troy
