flapbreaker-
The question of whether to use one or two tie-down straps has several possible answers.
1. Two straps are better than one because you still have one if the other one breaks.
2. The discussion we had earlier on another thread about keeping the boat centered when going around corners also relates to this question, and the answer might be-
A. Two straps
B. Four straps
C. Four straps and a big strap
To wit-
(Don writes)
One problem I do have is the fact that no matter how tight I make the transom tiedowns, the boat's stern still slides back and forth on turns. Stops when the bunker hits the outer strake, of course, but it is a tad disconcerting. Any hints? Or is this the usual C-Dory behavior?
Don
Do you have guide-ons on the trailer to center it when retrieving at the launch ramp?
I've never noticed my boat moving around on my EZ Loader trailer. My guide-ons are 2 x 4's, placed 6 inches below the rubbing strakes, from 1 foot in front of the transom to just ahead of the front windows and adjusted with 1" of clearance on each side to keep the boat centered. The metal support structure from the trailer frame upward to the padded 2 x 4's is made up of metal box channel at least as big as the 2 x 4's. I suspect the substantial nature of these structures keeps the boat from moving around. Some guide-ons are only about half this height, not as long or substantial, and/or not adjusted as tightly. Other trailers simply don't have them at all.
As an additional means of securing your boat to your trailer, I'd suggest you add to the vertically oriented transom straps which allow some side movement (kind of like a parallelogram or box without a bottom member). I'd add cross straps from the lower right of the trailer to the upper left of the boat and from the lower left of the trailer to the upper right of the boat. You could also add a single heavy duty strap forward of the transom, say about 2 feet, from the trailer frame up over the gunnels of the boat and back down to the trailer frame. Hope I didn't over do the correction possibilities! Joe.
