Foggy
Active member
- Joined
- Aug 1, 2013
- Messages
- 1,595
- Reaction score
- 1
- C Dory Year
- 2014
- C Dory Model
- 26 Venture
- Hull Identification Number
- TBD
- Vessel Name
- Boatless in Boating Paradise
Delphinus":ty68pzoe said:Very cool, Foggy!
Since I could see which direction the storm was coming from (i.e., west, south-west), probably could have employed your technique, in reverse, to predict wind direction when it hit. If pointing to center with left hand, out to side and slightly back, would have hit me in the back coming from south-ish...I think. Is this true?
Gerry
The idea is to track the center of the low and avoid the "dangerous semi-circle".
If you are in Ocean City, MD and the storm low seems to be passing south of
your position, you are in the "safe semi-circle" since the winds would be from
the east as the low passes you; winds circling counterclockwise around the low.
By itself, this may be bad enough.
But if the low travels to the north of you, the winds will be from the west.
Here you get the additive double whammy. The wind from the storm itself
moving east (1) and the west counterclockwise wind generated in the storm (2);
the dangerous semi-circle you want to avoid. This is usually for open ocean
when you get caught "out there".
I wouldn't leave port. a secure anchorage or navigate an inlet in either case
with an approaching storm often hailed a "Local Notice to Mariners" on VHF,
even "small craft warnings" in some areas.
Aye.
