It'll soon be time to Outfit The New Boat and I KNOW how much y'all hate to talk about that
A little background - I have a nearly new 16 (want a good deal?
) and just bought a nearly new condition 2007 22.
I have kept the 16 in a storage yard between my house and the nearest lake and will likely do the same with the 22. After a month of using the 16, I got tired of having to clean out the cockpit every time I pulled it out from storage. Leaves, rain, dirt - just the usual stuff. I bought a full boat cover from those good folks in Indiana. Best upgrade so far. Ok, only upgrade so far but still very good. The boat is clean and dry every time I go to it and putting the cover on or taking it off adds no more than three minutes to my whole routine.
For the 22, would you recommend a full cover, a cockpit cover or a camper enclosure? I don't know how much I would use the camper enclosure as I don't really need an "extra room" on the boat as I will be cruising for only a few days at a time and almost always solo. I wonder even about a bimini as I like the open cockpit.
The boat does not (yet) have curtains so a full cover would also prevent sun fading of the interior - but that's probably an overkill solution for that "problem"
The 16 cover is large but easily rolls up and I just toss it in the bed of the truck with a bungee or two over it. A 22 cover would, I think, be quite a bit bigger due to the cabin size.
Ok, I seem to be talking myself into curtains or shades and a cockpit cover. If I go that route, what is the best way to fasten a cover? I ordered the 16 cover with loops sewn in that I bungee to the trailer rather than snaps. I don't much like snaps but that seems the most common way to attach a cover.
Speaking of attachments - how would you attachment window coverings? Not looking for frilly curtains here, just fabric shades for privacy at night and sun fade protection in storage.
The boat does not have a windlass.On the 16, I used a plow with a bridle line setup so that I did not have to go forward to set/retrieve. That turned out to be serious overkill for my lunch stops so I now use a small folding grapnel that I just tie off to a stern cleat. With a little rode work I can position the boat at optimum angles to sun/breeze and retrieval is easy. On my current day trips, I anchor EVERY time I take the boat out but it's usually in three feet of water or less so sticking a boat hook in the mud would probably be sufficient. On the 22, I will be cruising overnight so I will need to use real gear. I should just get the windlass, right? The only thing I could see arguing against that is if I can EASILY stick my shoulders through the hatch and handle anchoring chores from there.
Kicker. The boat doesn't have one. I don't fish (too frustrating - I go out to RELAX) so I don't need to troll. I would use a kicker for three purposes:
1. Get me home - if the big horse fails, I want to make it home on my own.
2. Close quarters steering - not sure how practical this is but I thought I might be able to tiller steer a kicker from the cockpit when coming back to the dock/launch ramp. Coming in solo requires some creativity. Using the kicker as an everyday aid to docking also increases the chance that it will work when needed.
3. Sacrificial power - I like to poke around in backwaters that tend to be poorly charted if at all. I also poke around in areas of the lake with standing timber. Poking around using the kicker might be a better idea than using my main means of propulsion. I've only hit one stump but that was enough to lead to a more exciting than necessary return to a remote ramp and a long walk back to the truck.Or I could just be careful. Nah....
What would you recommend for a kicker that would satisfy these needs? Electric start with pull cord backup? Tiller steer but also slaved to main steering?
One thing I have not liked dealing with on the 16 is the gas tanks. Being a sailor, I seldom dealt with fuel and when I did it was diesel in integrated tanks. These 6 gallon plastic tanks drive me nuts with their bulging, fumes, leaks, etc. So I don't see myself carrying fuel for the kicker outside the main tanks. I realize that is not totally redundant but I'll accept that risk.
I will be scouring your pictures for great customization ideas and then scouring service tech listings to find someone who can make the modifications because I am tragically incompetent when it comes to tools and stuff. Seriously, velcro challenges my skills.
Thanks for all of your future suggestions. I really appreciate this board and the way you all share your wisdom.
