meade":216zpxm3 said:
What is the all up weight, boat, fuel, trailer of the C-Dory 25
Hi Bud,
When I weighed Wild Blue, it came out at 8,700 pounds. That was with some of our cruising gear (dinghy, motor, generator) in the bed of the truck. Less than 1/4 fuel - we always tried to tow with the fuel as minimal as possible, then fill up right before launching. With a 100 gallon fuel tank in the 25, you are looking at over 600 pounds of fuel - no advantage in carting that down the road.
When home in Texas, I rarely fueled above 1/2 - when out cruising, we always fueled to full. Also, when we went out, it was usually for several months at a time, so you tend to load differently than when using the boat locally.
Our 2007 CD-25 had the Decraguard interior, prior to the switch to a molded fiberglass interior - not sure which is heavier. We had been in an earlier 25 that had a lower dinette than ours - less storage under the dinette floor, but probably less weight, as well. That will also make a difference in your view out while seated, I assume. When ours was built, the factory tried for standardization, but it seemed that boats were different, depending on factory rigging vs dealer rigging. Ours had almost every option the factory offered at the time.
The factory told me the boat would weigh "6,500 pounds, all up, on the trailer." They missed that by a ton. Other 25 owners I spoke with who had boats of a similar era were all above 8,000 pounds on the trailer. Speaking of the trailer, ours came with a King Saltwater Series galvanized trailer; I was told the trailer was 2,000 pounds. That's a pretty "round" number, and I would guess it weighed more than that, but I never weighed the empty trailer.
We had a truck specialty shop set up our hitch for towing: hitch height to make sure the trailer was level, and tongue weight at approximately 800 pounds. We had to move the bow winch height to get the best balance.
When we took delivery of the boat/trailer, the trailer had surge brakes. After the first year, we converted to electric over hydraulic - should have done that right off the bat.
We wound up buying a 3/4 ton diesel pickup just for towing the boat. We picked that up a month before taking delivery of the boat - our retirement plans were for towing that boat all over. Great truck, and we were very happy with the way it handled the load of the boat (and later, a HitchHiker 5th wheel).
Tim and Mary are towing with a Tundra, and said they feel it is up to the task. I think Pat Anderson had a Titan before getting the 3500 diesel. I heard that one owner towed with a Toureg diesel. We all have a different comfort level, but be sure to check the mfg specs on the specific vehicle, and know that any weight specs you read from the boat mfg are likely way low.
Lots of decisions - get past this angst and enjoy the cruising!
