Installed a Lone Star GX2 anchor winch
AKFisher
Apr 7, 2019
28
2013
NELLIE GRACE
I had a Lone Star GX2 anchor winch installed on my 22 Cruiser. it is amazing. About 425 feet of chain 1/4 inch Dyneema line. No more having to walk up to the bow and drop or raise anchor. It will make it a lot easier on the cool Alaska mornings. [/img]
Nice keep all the stink up on the deck.
Impressive spool winch! Did you really put 425 feet of chain, or is that a combination of the Dyneema and chain--if so, how much of each?
What splice did you use to the chain, and did you use a thimble?
There is about 400 feet of Dyneema spliced into a bout 10 foot of nylon line as a snubber which is linked to about 20 foot of chain that is hooked to a swivel and then the anchor.
Update to the break down of the complete rode:
Lonestar GX-2 winch. This winch is holding 380' of Dyneema, 12' of nylon and about 30' of chain, for a total 420 feet of rode
"No more having to walk up to the bow and drop or raise anchor".
How are you going to keep it from loading up on one end or the other? Guy in Palmer fix you up? Nice winch!!
:thup :beer
When I bought my boat, the chain was attached to a swivel and the swivel to the anchor. I changed that immediately to....the chain to the swivel, the other end of the swivel to 3 links of chain, the other end of the 3 links to a shackle, then the shackle to the anchor.
My local chandler showed me a drawer full of bent and failed swivels that had been attached directly to the anchor. When there is side tension (pull) on the swivel it becomes the weakest link in your ground tackle.
Martin.
tsturm...I was told that with how far back it is mounted that it should load evenly. It was recommended to go to a deep spot to let it out and rewind it. This would allow the line to releave any twist and tighten the line on the spool. It should also aid in loading up the spool evenly.
I am open to any other recommendations
"My local chandler showed me a drawer full of bent and failed swivels that had been attached directly to the anchor. When there is side tension (pull) on the swivel it becomes the weakest link in your ground tackle."
I second what Martin says about the swivel. When I went to the new anchor (Rocna) several years ago, I was going to put on a new swivel. After considerable research bot here and other sites, and talking with many experienced anchoring folks, I opted to leave the swivel out and get a good shackle, seized on well and have not regretted that since, with somewhere over a hundred nights on anchor since and no issues. The Rocna always comes up right.
Great, no recommendations just questions. I have been looking at that winch for a couple years.
Let us know how it works!
:beer
AKFisher, Now that you had a bit of time to use it, how are you liking that Lone Star GX2 and the setup you got? Did you purchase the unit in Palmer?
Everything worked extremely well. I have anchored as deep as 315 and I spent many nights on the hook. Never had the thermal fuse pop. It has been worth the money without a doubt. I purchased it and had it installed by Ashbreeze Boat Works in Anchorage. They did great work and kept all wiring and set up very clean looking.
Hi,
I am looking at adding that GX2 on our 22 cruiser. Do you have any more pictures of the bow/ anchor set up? There is just one photo of it in your album and I am looking for more details of the mount/ bow cleat/ roller set up. Thanks!
