Cockpit drainage - 19
curioustraveler
Hello,
I'm in the research/shopping phase and unfortunately don't have any models close by to see in person. Can someone explain the cockpit drainage situation on the 19? I've read that they aren't self draining, but I also read posts about the location of scupper drains. Does the cockpit have any drainage besides the bilge pump?
I'll be leaving her in the water so she'll collect rainwater and I'd rather not depend on the bilge pump to dry her out.
no scuppers, not self bailing.
most of us use a sloped back cover at the marina.
see my pic 187
Bilge pump.
I know a non self bailing cockpit can sound sketchy but C-Dorys aren't sinking and the deep, secure cockpit is one reason I like mine.
Pump will be slower than hose putting water into the boat--but will get most of it out. You may have to finish up the last bit with a mop or sponge. If the boat gets up on a plane, all of the water drains aft to the small sump just in front of the transom. The 22's, 25's and a 19 with a solid bulkhead, may have a second bilge pump just at the aft bulkhead (where door is, either inside or outside), and thus get 99% of the water out.
Coming from a sailing background, I did feel that self bailing was necessary, but having owned two 22's, I decided that with dry deck and perhaps a high density foam mat on top--or one of the vinyl loop mats, that it worked very well. The boats are light enough and have a lot of reserve buoyancy, so the stern rises quickly when waves are come from aft or aft quarter. You certainly can get some spray in. But even boats that are "self bailing" have some leakage thru hatches on the cockpit floor.
Thanks everyone for the info. Sorry to be beating this to death but I guess what I'm asking is, bottom line, does the lack of drainage make it difficult to leave the boat in the water vs on a trailer? I ask because this is a problem with my current boat. She's a 16 foot skiff and we keep her in the water at our neighborhood marina. We had a ton of rain this past summer and she kept filling up with water. Leaves or other materials clogged the bilge pump and it seemed like almost every time I checked on her after a heavy rain she was filled with water.
I know a C-Dory isn't going to sink with rain water but I can imagine it'll be a huge pain if I'm gone for a few weeks and I come back to find her cockpit full of water due to a blocked pump. Or when I wash her down there's no drains for the dirt, soap, and other matter to drain out.
As far as leaving the boat and rain, the slant back cockpit cover will make it virtually water right. My boats with those covers didn't get any water in the cockpit. I would wash the cover each year, then treat with 303 fabric protectorate, which keeps the waterproof characteristics of the Sunbrella fabric. The bilge pump will allow most of the water to be pumped out.
In the water the boats are not self bailing. If you leave it without cover, or put water in the cockpit--it must be pumped out.
At first glance your drainage concern appeared to be singling out the C-Dory 19 and C-Dory's in general. But if your issue is with leaves clogging drains, that sounds like more of a result of where your marina/slip is located, and you're likely to have that problem with any boat, including self-bailing styles. That is, unless you properly cover it as suggested by others.
With any skiff like a Whaler that is wide open, the entire boat is collecting water. The benefit with a C-dory is that most of the boat is covered by a deck and cabin, and then you're left with only the cockpit to worry about protecting, which is easily accomplished with a slant-back cockpit cover. In that regard I would think the C-Dory is probably one of the better options out there to address your concern about rain and leaves.
I can see that you initially started looking at a 25, then a 22, then a 16, and now a 19...but what other brand of 19 footer is even in the same category as a C-Dory 19 with a hart top cabin? You might also look for an Arima 19 with Hard Top. Like C-Dory 19/22 it is not self-bailing, but does have a raised deck that drains to a bilge, and due to the added beam it might check more of the boxes you've expressed in your earlier posts. You can even get them with configured with 2 back-to back seats to seat 4, as you've previously mentioned as desirable.
Good luck with your continued search for the perfect boat, it's hard to find one that does everything!
-Mike
OP: I wouldn't worry too much about it. I also was worried about the lack of scuppers when I bought my 19 but it wasn't a big issue in the real world.
As long as you dont take a large wave into the cockpit , you'll be fine.
The 22s aren't self bailing either and most Brats arent losing sleep over it.
MikeR you've done your homework on me! You're right...we've been all over the place with trying to find the perfect boat. It started with our neighbor with a 22 Cruiser that has sat in his driveway untouched for several years. I fell in love with the style. For numerous reasons (budget being one) we decided it wasn't the best boat for us right now. I toyed with the idea of a 16 but don't think that'll really accomplish what I'm hoping for. Now I'm fascinated by the 19.
I'm actually not concerned with taking water over the sides since the bilge pump will take care of that. I'm just curious if any C-brats who leave there's in the water find it annoying the cockpit isn't self bailing (when washing her down or after a heavy rain storm for example.) My experience has been with sailboats that are all self bailing so that's where I'm coming from.
Sounds like no one seems to have a problem. And a canvas top certainly would be on the wish list.
There is a reason the 22 is the most popular C-Dory model. If you like the idea of the 19, the 22 is essentially a 19 with a galley and a dinette... meaning you can spend more time on the boat in comfort.
Yes, there are happy 19 owners, but there are a LOT more 22 owners (which also means there are far more 22s on the used market). I am not trying to talk you out of anything, just suggesting that you might want to compare what you get for your money with both boats.
Good luck with the search.
I'm with everybody else in this post. Drainage for a CD22 is not a problem. It rains a lot here in the midwest, especially in the spring. I trailer my 22 up to L. Michigan every couple of weeks fish from two to five days at a time for salmonids. I slip the boat at the marinas in transient slips.
The two bilges in a 22 (one under the motor well and one at the cockpit) do a great job of keeping the water out of the rear deck. I've been is some pretty heavy deluges in the slips and out on the water, and never had to worry about how the water gets out. The bilges are wired to automatic and come on as needed (I can also turn them on manually if needed).
Bob is right about the slant back/mooring cover for the rear cockpit. The cover works very well and directs water to the motor well which drains through two holes on the starboard and port ends of same. I do not have one of these covers yet. I'm working on fabricating a cover now.
Of course, their is a central drain hole in the 19 and 22 and the water drains out while on the trailer should any water get in.
All this good drainage is contingent on keeping the bilges and cockpit drain clean of course, and I'm sure other boaters work as hard as I do keeping pumps operable and drain holes clean.
Good luck
Newer 22s only have one bilge under the motor well at the aft center of the boat. There is no bilge pump in the cabin any more (08 and later).
Isn't there a bilge (and pump) under the step between the cabin and the cockpit, with a small trapdoor right under the cabin door on the 22 Cruiser (2008 and newer.)
Not on my boat. No step either.
If you are going to leave any of the non self bailing models in the water where it rains frequently you are most likely going to want to invest in a cockpit cover. Money well spent. Whether a camper back or a slant cover, it will also make over nighting more pleasant. I was never comfortable relying on the batteries to keep the boat dry on my 22 Cruiser. On my 25 Cruiser, I've found the floor hatches leak like a sieve, so same same. Where there is shore power, less of a problem if your boat is so equipped. But having a cover equals a little more piece of mind.
One final comment. On my 22 I put heavy duty bar/kitchen mats down in the cockpit. Used them for 13 years. I picked them up at a restaurant supply store, cut them to size and never looked back.
JoeDub
I should add one comment about the non self bailing models. Carry a bucket at all times. A hand pump is good for clean up, as well.
Back in 2000 when I had just purchased the first Betty Louise I was by Orcas Island solo fishing, drifting with the current. I was brand new to boating. Both engines off. Beautiful, sunny day, quiet, just the sound of the cormorants and gulls. Fishing in Paradise.
I looked over my right shoulder and could see that I was drifting backwards into a rip. Hmmm. Curious I thought. Did I mention I was brand new to boating? If you've never boated up here, a rip is where two fast flowing bodies of water collide, forming a sort of standing wave. Well, I drifted stern first into the rip and the rip sucked the aft starboard quarter of the Betty down enough so green water started breaking over the gunwale in a continuous flood into the cockpit.
Throwing my pole down, I ran into the house and tried to start the starboard engine. I had twin Honda 40's, carbureted. The starboard engine didn't start right up. Looking back at the cockpit from the helm, I could see water continuing to pour over the gunwale. Did I mention that the water around here can be many hundreds of feet deep? And that it's freaking cold? Really getting worried, I switched over the port engine. It started right up. Throwing the throttle forward, I scooted out of the rip and into clear water.
The cockpit had filled up to the bottom of the bulkhead door and I grabbed my bucket and bailed like hell, finishing up with the hand pump. The 1200 gph Rule bilge pump didn't make a dent against that flood.
I started off this note by saying that with the non self bailing models, you should carry a bucket at all times. The simple fact is that you should carry a bucket at all times no matter what boat you are on the water in. But on non self bailing models...
JoeDub
Wow! Close call.
Having learned to sail in the Columbia Gorge and gone out in all conditions I arrogantly thought I knew something about waves.
The first time I got into the Point Wilson tide rip I may have said 'oh poop' or something similar, I did learn a valuable lesson though.
The Gorge
