Pat Anderson":2r9pslbo said:
So, Jim, why don't you walk us through creating the calendar in Photoshop 101? I have CS2 on the iMac, played around with it a bit after your intial post on PS 101, my son Barrett (who uses PS daily in his job) showed me a few things, but I really am a dunce with it...would love to be able to produce a "simple" card or calendar or something...
OK, here it is:
Photoshop 102, creating a card or calendar
* Decide the size you want the project to be; in this case I wanted an 8.5x11" calendar. Open a new file, 8.5" wide, 11" high, 300 dpi. Select "All" (you will see a dotted line around the whole file). Go to Edit>Fill, and select Foreground Color (be sure you have the color of the background already in your foreground). You now have a solid color file. With a contrast color in the background selection, go to Edit>Stroke. Set the width for 20 pixels, choose the background color, and select Location: Inside. You now have a solid color with a contrasting stripe all around it. If you want to dress it up a bit, go to Filter>Texture, and pick a texture to use on the solid color (there are plenty to choose from).
* I got the dates from a template in iPhoto (a Mac program), but there are plenty of 12 month date set-ups available on-line; this way, you don't have to insert every date in every column. Copy and paste those onto another layer. This will likely be black numbers on a while background. Go to your "magic wand" tool and select the background of this layer, and use the same technique as above to make it any color you choose. Size this layer to fit the file; to to Edit>Transform>Scale and you can make it any height or width... leave room for your photo.
* Select the photo you want in the calendar. Size it to fit the space in your file. Again, select "All" and stroke it with the same color as the contrast (background color), width 15 (or whatever size pleases you). Copy and paste that file into your calendar file.
* You can add the year or title by using your text tool.
This is another project that takes longer to type than to do. All of the above can be done in just a very few minutes, and you have a custom calendar, ready to be printed on your home printer or taken to your local photofinisher for an enlargement. If your local photofinisher only makes 8x10, you should size the file to that instead of 8.5x11 from the beginning.
You can use this same technique to make greeting cards, just size appropriately... if you do a 3.5x8 file, you can put three cards on a sheet of 8x10 stock.
Now, if you don't want to go through all the steps, you can take your image to a photofinisher and they will likely have a template for a calendar; most of the on-line places have these available, as well. I prefer to make projects that color coordinate with my images - not something available from the local photofinisher. However you choose to make it, you can also laminate the calendar (Kinkos) and it will be waterproof on your boat!
OK, Pat, I have now given several Photoshop lessons at NO CHARGE... I assume that we will be able to come to you for free legal advice, right? 8)
