jkidd":2xte2h7y said:Pat there are a lot of videos up on YouTube that you can watch to get an idea. Etrailer.com has a lot also. Looks like your having fun anyway.
BrentB":2m43gvih said:Pat
Here is Timken pdf showing various bearings issues
Good Luck
BrentB":3uuhhp1c said:The cylinder is the piston and looks fine as does the seal around it. Nice pics, too
Pads look like they are fine just rusty on the back and have plenty of material on them. (or replace the pads)
wire brush the back side (metal) side to clean off the rust
reassembly both brakes on that side
rotate to check if binding
have someone apply brakes on and off while you check the calipers are applying pressure to the rotor. Brakes on the rotor cant be turned and brakes off the rotor turns freely. You should be able to see the piston push out and retract
make sense?
BrentB":154fca6b said:How old are the calipers?
BrentB":3n9c60e3 said:Hey
You need to retract piston to install caliper
Pat Anderson [ATTACH type="full":23zcu0x6 said:117169[/ATTACH]
BrentB":bajazk2y said:I think it is fully retracted in the pic. If pressure was applied it would extend out more
BrentB":ro9fs4v3 said:I think it is fully retracted in the pic.
potter water":3h0udrej said:time to limp it to a trailer professional who knows what they're doing. A c clamp is not normally needed to push the piston back in. The piston should move back in easily without pressure on the back side. It is either frozen...unlikely...or there is pressure in the cylinder that is holding the piston in place from the back side...also unlikely as the piston would be popping way out. In any case, you are not going to get out of this one working in the driveway. Just my guess.
