Default Re: Opinions On C-Dory Boats
entirely lifted from a non-advertising web site. esearch qmarine
The C-Dory 22, 19 and 16 share the traditional dory hull that makes these boats so seaworthy and economical to run. What makes these hulls so economical and so easy to plane with relatively low horsepower is also what speed limits them in rough water. In ugly conditions a C-Dory is going to take you safely where you want to go but at its own pace unless you're prepared to suffer.
So you want a nautical version of the Volkswagen camper van? That's what you're going to get with the C-Dory 22 Cruiser. It's the most boat you can get in 22 feet and power with the lowest horsepower in a planning hull. It has basic, functional amenities that are quite comfortable and adequate if you're not looking for velour, teak and mirrors! And it isn't a Porsche! The CD22 will operate safely in conditions most of us would prefer to stay out of but if you want to remain comfortable you'll slow down and let the hull "do its thing". The C-Dory will motor along happily in the low to mid teens getting great fuel economy while keeping its occupants dry, comfortable and warm (especially with the Wallas stove/heater). With a very shallow draft and trim/tilt on the outboard you can sneak into small coves, estuaries and backwater areas where the typical 22-footer would never venture. Its light weight and low profile also make the CD22 a great boat for trailer use and for exploration of all the great places to boat that are usually denied to "cruisers".
The CD19 is built on the same hull as the CD22 but shortened in the mid section by 3'. In fact, from the helm station forward the CD19 and CD22 are identical. In order to reduce weight and cost the CD19 had been built with an open back cabin (usually closed in with a drop curtain or camper canvas). The cockpit can be completely hosed out for cleaning. The CD19 carries the same 40-gallons of fuel (in 2 20-gal tanks) standard as the CD22 and will run along quite nicely on a 70 to 75 horsepower 4-stroke.
The C-Dory 16 is the baby of the line. It shares the same dory hull as it's big sisters and is quite seaworthy but it is a small light boat so some prudence is called for although it's a "large" 16. The hardtop, quality construction and high class fittings make this boat quite unique. The 16 Cruiser is about the smallest boat you can get into with a full v-berth and will camp cruise two quite comfortably. They can be outfitted to the "9's" and are beloved by their owners. The Angler version frees up some cockpit space and gives up the v-berth (but still has storage forward) for the fisherperson and is great for crabbing and shrimping too. And with its hardtop it makes a pretty good Northwest runabout. The Cruiser works well with 40 to 50 hp, especially the 4-stroke engines. I've heard of the Angler's with as little as 30 hp doing pretty well.
__________________
Team Savage
Team Gregor
Team Rye Whiskey
Team Backcountry Hunters and Anglers
