potter water
- Joined
- Apr 12, 2011
- Messages
- 1,076
- Reaction score
- 0
- C Dory Year
- 1997
- C Dory Model
- R-21 Tug
- Vessel Name
- Poopsy
The sight of half a cup of water coming out of the lower unit of my port Suzi was terrifying. The starboard engine was putting out only good clean hypoid oil. (Doing my winterizing).
I don't know where to go from here. Does anyone have experience with the concerns I should have about having run the engine during the summer, possibly with some water in the lower unit? I don't know when during the season that the leak started.
I've worked on a couple of old two stroke lower units and just removed, cleaned the interfaces, put in new gaskets and o rings and things were fine.
Anyone have thoughts about where most of these kinds of leaks come from? Or do they simply occur at any place where there is a seal or gasket.
I'm making a fitting to allow me to pressurize the lower unit and see if I can get bubbles. Any one else done such a pressure test and what did you use to get the pressure into the lower unit?
