What type of adhesive to re-attach sliding window latch?
Stimpys Dad
Nov 1, 2003
61
1982
22 Angler
Hull Identification Number
MFN220800782
Stimpy
HI all,
A little help please.
I replaced a broken sliding window and need to put the latching handle back on.
What type of adhesive or sealant do I need to use?
Thanks Doug Cruickshank, "Stimpys Dad"
I used a piece of double sided tape.
3m VHB double side tape, should be able to find it at Home Depot. It comes in different pounds per square inch. So get the highest one.
We have used both epoxy and silicone. Glass is hard to adhere to .Of course make sure its very clean [91% isopropyl is good and cheap]. Keeping the window tracks lubed helps alot !
Marc
Marc,
What do you recommend as a lube?
I just happen to have spoken with Diamond Seaglaze about this very subject on Friday. The support person I spoke with said to use a silicone adhesive - or even better- to use a bead of 3M 4200 in seating the handle.
As to the windows sticking - like all of us I've been dealing with sticking windows, and then, sooner-or-later, the handles popping off. Frequent lubing doesn't help for long. In my experience, the tracks pick up lots of heavy soil quickly. The lube may even trap the dirt that creates the sticking.
I was on board recently during a very heavy downpour. My boat was tied up in its slip. The heavy rain was falling on a slight angle from the port side. I left the starboard cabin window (the leeward side) open to enjoy the cooling. After a short time the the runoff from the cabin top dripped into the the window track and flooded it. After closing, the runoff continued dripping down the outside of the glass into the track.
I am looking into installing a gutter along the edge of the panel on the cabin roof side. (I'm speaking of the panel with the dark color trim above the windows.) I think the soil/crud that fouls the window tracks is carried in the runoff from the cabin top. I want to channel that runoff back towards the cockpit and keep it away from the window tracks.
My boat is kept in the water at an open slip. A fair amount of airborne dirt, pollen, bird droppings, spider webs, etc. collects on the cabin top and runs off along with the rain and dew. That's probably where all the crud is coming from. So when time allows I'm going to put some gutters on and see if that will help keep the windows sliding freely.
FWIW - Here's are links to the Diamond Seaglaze info:
http://www.theamtstore.com/handles/d15h ... 12506.html
http://www.theamtstore.com/static/manua ... ctions.pdf
Hope this is useful information.
Take a look at this gutter.
http://rvgutters.com/
Bill Kelleher
But I like it here. LOL
Bill Kelleher
Wefings":2y7peifd said:
Bill , get your mind out of the gutter !
Marc
I have used Liquid Rollers with success.
Liquid rollers is a silicone spray--any of the "Dry" silicone sprays work well after a good wash out of the grove the window slides in.
Bill K -
Many thanks for the link. Does anyone here have direct experience with EZE Marine Gutters?
Lucky Day":2rbotn56 said:
Bill K -
Yes, I used them on our Monk 36. Helped to keep light rain from entering the open windows in the salon and aft stateroom. Make sure you install with a slight angle to insure proper draining. During a heavy rain, they will likely overflow as the channel isn't very deep.
Easy to install and met our expectations.
