- Joined
- Nov 1, 2003
- Messages
- 8,650
- Reaction score
- 0
- C Dory Year
- 1987
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- DOR22286A787
- Vessel Name
- Sea Wolf
cdory25":3qx6m1a6 said:UncleRichie":3qx6m1a6 said:Do you have room inside for some bows/ribs my 22's roof is not strong enough to walk on but I don't have enough headroom to put anything in.
Richard
Great idea! 6' 5" headroom leaves plenty of room for ribs. What do you think, glue or bolts? Wood or metal?
Off the top of my head, here's what I'd do:
Use solid fiberglass sail batten material for the ribs, the kind without the wood centers, say 2'' wide.
If it's too stiff to bend, find some lighter variety that will and laminate several layers up in place one at a time overlaying them and bonding them with resin.
The thicker the material, the stronger it will be from the extra glass, of course, and the extra thickness will stiffen it up like a box section.
I'd test it out gently as I went for generating the support desired, deciding how many layers to add as I went.
The roof interior will have to be sanded down to resin to allow the lamination.
One could put a few layers of glass tape up initially to help spread out the load, then follow with the batten material.
If you thought the downward thrust on the outside ends of the resulting stringers was too great, through-bolting with machine screws to the cabin hull at the sides, not the top, could be used. Small washers on the outside and fender washers on the inside. Seal it properly!
The ribs can come down quite a ways between the windows, but only so far where the windows block them, an engineering considertion.
If one can't find a suitable batten material, I know there are products that are ready-made set-up fiberglass ribbons that are used to form hull and other shaped structures by bonding them together over forms. These would be an even better material than the battens to work with, if cost-effective. Does C-Flex sound familiar?
A second approach would be to reinforce the entire interior structure by laminating a core over the entire interior.
Sand everything down, apply a relatively slow curing resin (for work time), put up the core (many possible types), let it cure, then add an interior layer of glass.
Might be simpler in the long run.
However, any glass work inside the hull is going to be dirty, dusty, and somewhat difficult to do. Worst of all, you have to not mess up the interior hull cabinetry, etc.!
As a third alternative, someone with very good cabinetry skills could make cardboard templates of the interior hull shapes at various stations and laminate up wooden beams to glue/through bolt into place with resin. How about alternate light and dark banded wood laminate to match the flooring laminate (if you have it).
Would be a fun project!
Fortunately, my 1987 CD-22 Cruiser is near rock-solid on the roof, as it is everywhere.
Joe. :teeth :thup
