I'm jumping back in this post with a couple of questions.
First, I'm curious as to why one needs to build a ground plane out of copper tape on a C-Dory. I thought that the ocean was the best ground plane one could get, so building a Farady cage would be counterproductive.
Second, Why would you want 50' of copper tape? RF frequencies travel on the skin of a conductor, so you need one with maximum surface area, but that only only needs to go from the radio chassis ground to a water ground, such as a metal through hull. In fact at the frequencies we're talking about, I've had good luck laying the tape on the bottom of the hull and using capacitance to sink the noise. On Our Journey, I installed a sintered copper plate, but that's overkill.
