Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,766
- Reaction score
- 116
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
Good decision Pat. The water in the Northern part of the loop, can be cold--or it can be fairly warm--depending on the year, and body of water. But there is enough in the marine growth section to make it worth while.
The zincs became a slightly different issue. Probably OK--if you watch them. But marinas or boats occasionally are miss-wirred, and there can be stray currents from other boats. This in itself can cause issues. You will probably want different zincs on the motor as you go along--Mg for the upper part, aluminum for brackish to sea water--check with your friend.
Also have the internal zincs done if you have not already done them.
What is your plan for oil changes, and lower unit lube change? This is one area where it is actually easier with inboard engines. On our long voyages where I had to run the engine for several thousand miles--such as the run from Panama to Calif--I would stop the engine and do oil changes when at sea. Also the injector pumps on my diesel had a change interval of 50 hours--we cheated a bit on that one--and did it at 150 hours. We were running the engine almost continuously for over 25 days.
