Grumpy
Active member
- Joined
- Oct 10, 2005
- Messages
- 1,607
- Reaction score
- 3
- Vessel Name
- Kingfisher II
Doing some head scratching over water heaters and would appreciate any input, help or advice (assuming it's physically possible and legal!!)
Since we have outboards there is no ready source of coolant water to act as a heat source, so:-
Electric seems to be either storage and/or intstant, point of use heaters.
The storage type are well documented, lots of choices and no real problems there except choice and $$$.
Point of use require high power input which is possible with shore power, generator or for short time with the 2K inverter.
My real question lies around the use of gas (propane) or diesel since we have both available in reasonable quantity.
Gas heaters only seem to exist in "houshold" varieties which I suspect would not endure very long in a marine environment. Anyone know of any "marine " gas heaters ? I can heat many gallons of water using my propane stove so, logically a gas heater should be very efficient.
Diesel seems a logical choice since our Wallas forced air heater seems to be able to produce large amounts of heat for very little fuel usage.
I found the following marine diesel heater and was wondering if anyone has any experience with it since it appears to be readily available locally
http://www.itrheat.com/waterheater.html
Thanks in advance
Merv
Thanks in advance
Merv
