Greetings!
Never thought I'd be asking this question, but here goes:
On our new (to us) Rosborough 246 we need heat. I've decided on diesel heat with thermostatic control. The existing Force10 propane cooktop is worn and I'm not jazzed about having hard-installed propane on the boat anyway. Installing a dedicated forced-air diesel heater PLUS a new cooktop would be tricky and fairly expensive. For that option I would go for the Wallas 22gb heater unit.
Though I have heard from multiple sources they are frustratingly unreliable, and had thusly dismissed them from my heater search, there is an obvious appeal to choosing a Wallas heater/stove combination. It would fit the existing cooktop cutout for an easy install, would leave the cabinet space underneath unmolested, and would cover both heat and cooking. Though we intend to add some inside passage cruising and boat camping, our need for heat and cooking is probably less than with most cruisers. We could use a ceramic cube heater to supplement whenever we have shore power, and our jetboil for our morning French press.
Now my question: I have heard that the newer generation of these heater/stoves is significantly more reliable than the original versions. What are your honest thoughts? Is this simply a case of my wanting them to be something they're not to suit my immediate needs, or have they actually demonstrated major improvement?
Thanks for your input, Mike
