Grazer":7emjz3m4 said:
With all the different respirators out there, can you suggest one to use that is all purpose. I assume one would use a respirator with filters to protect against organic vapours (i.e. solvents, paints, contact cements etc.). Would this also double as a filtrate for dust particles from sanding fibreglass, uncured epoxy etc.? What is your preference?
Good question and I fully support people interested in a respirator when working around boats :thup I can give you some information based on my experience. (Synopsis at bottom below asterisks.) Essentially, there two main types that I know of. One is "supplied air" and one is just "air you breathe in from the atmosphere through the filter." The former type are necessary for certain catalyzed paints (such as two part LPU's), but would be nice for anything. However they are more expensive and not as "limber" to move around in. I don't spray catalyzed two-part paints, so I have always used the "non supplied air" type and have no direct user experience with the supplied air type.
So, in the non-supplied-air type, there are the basic paper white masks. I don't use these so can't comment. Then moving up there are the semi-disposable types (they look like a "good" respirator but don't have replaceable cartridges). I used one of these at a job for occasional use (it was supplied to me) but didn't like the fit as much as my own (better) ones with the replaceable cartridges.
The next step up are the ones you can replace the cartridges on. These come in a variety of face-mask types, with various cartridges that you can fit (for various purposes) and parts that you can replace. There are half-face (cover mouth and nose) and full face (also cover your eyes). I really, really like the full face type for doing anything dusty, but, alas, I have a hard time finding one to fit, so I usually end up using my half-face one plus safety goggles, and enduring the "gap." I would prefer to use the full face one though. OTOH, if you are not doing a lot of things like sanding fiberglass overhead, the half face one is good, and easier to store, etc.
There are a few good brands. I look for ones wherein the face part comes in sizes (i.e. S, M, L), and I have spent a bit more for the better "rubber" in the mask part. A good basic respirator is the 3M 6000 series - my full face respirator is a 3M 6000 series. For my latest half-face respirator, I went up to the 3M 7500 which has a slightly better "rubber" face mask part. I used to have a different brand (Survivair, IIRC), and it was fine, but I ended up in more places that carried the 3M cartridges and parts, so I switched to using 3M respirators. You can see them here (or many other places):
http://www.envirosafetyproducts.com/3m-respirators.html
3M has filter selection guides that show you what to use for various hazards. I typically carry three different filters with me: The 6001 organic vapor cartridges (just plug into the respirator body) with the P-95 (dust) pre-filter (held on by a pair of retainers that you can re-use) And the 3M 2097 (plugs in and is used as a single filter) for tasks where they will be adequate (they are lighter weight and cooler to wear).
Once I had respirator(s) lying around (do be sure to store them such that they cannot "suck up" vapors in storage), I found myself using them for so many things. No more painting the living room while breathing fumes, for example, even though that's not supposed to be "dangerous." I'm sure it can't be healthy and it's more pleasant to not smell it (you can't smell the fumes if the respirator is working properly). Likewise for dusty work. I don't just use it for "special occasions."
So, upshot, I have a 3M 7500 half face respirator and a 3M 6000 series full face respirator. I carry the 6001 organic vapor cartridges with the P-95 pre-filters (and retainers), plus the 3M 2097 stand-alone filters. I also have a set of disposable clear face mask protectors for the full face mask (prevents scratches on clear view-through part of mask).
