I am the owner of a 2006 TomCat. I am writing to this forum as a courtesy to fellow TomCat owners to save them time diagnosing two particularly problematic factory installation problems. The first problem was with my gas tank. The factory installed hose that was connected to the metal fill receptacle was too short to be properly clamped, so it disconnected under normal boating conditions. After many guest complaints about gas fumes and after filling my bilge with gas one day, I finally diagnosed the problem and extended the hose. A properly installed hose of the correct length from the factory would have prevented a potentially life threatening danger. My second problem has been with the key switch installation for my two Suzuki DF 140s. The cable that leads from the engines to the key switch was not properly secured to the hull. Under normal boating conditions, the loose cable that connects to the key switch with a dozen or so bullet connectors flopped around inside the hull and caused two of the bullet connectors to disconnect. This caused my port engine to shut off completely while I was on full plane, resulting in a dark, dangerous, multi-hour trip to safety. Both problems were not overly difficult to correct, but resulted in many days of frustrating diagnosis that I hope others can avoid in the event they have experienced the same factory defects.
