joechiro30
- Joined
- Sep 24, 2014
- Messages
- 147
- Reaction score
- 0
- C Dory Year
- 2006
- C Dory Model
- 255 Tomcat
I installed the garmin reactor 40 on my twin 175 suzuki tomcat 255. The heading computer is in the middle on the wall under the berth at the center. Seatrial wizard went fine and auto pilot was working great for about 20 hours. I noticed that my steering was not working at 100 percent like it felt like there was some air in it. After a long cruise the autopilot heading shut off and the GHC 20 doesn't read the heading from the computer. Called the garmin support and they said that air in the hydraulic system could cause my AP to shut down and when I tried to re calibrate using the dealer mode. The seatrial wizard won't allow me to finish the 1.5 turn to calibrate the AP. I bled my hydraulics and will try to sea trial it again.
I have had issues with air in my steering even after buying a new unit. Sea star. Every time I reverse it seems to do unlock air or something. I don't know but my steering has had issues every time I reverse hard. So I try not to reverse hard if possible. Has anyone had issues like this with your AP on your tomcat. Any tips and advice would be appreciated. I've been spoiled with the AP and I don't want to do any long cruises without it.
Joe
Forgot to mention that my lock to lock test failed but I was able to bypass that test the first time. I can't seem to get the lock to lock test to pass and work properly even after bleeding the system over and over again.
Joe
