Good day all-
I am installing an Espar D2 on my new (to me) 2012 22 foot cruiser. The instructions state that the hole drilled around the thru hull exhaust fitting must leave 3/16" clearance between the boat hull and the thru hole fitting, i.e. I must over drill the hole.
What would be the best way to seal this hole? Epoxy? Just applied to edges of hole or try to over drill, fill entire hole with epoxy and then drill again? I think the hole would be to big to do this in a vertical position and have the epoxy stay in hole. Is epoxy heat resistant enough for this application? Is there no balsa in the hull side, so I don't need to fill it with anything, just go for it with no epoxy and the fiberglass raw edge will be fine with no additional sealing?
Also, the fitting comes with 2 heat resistant fiber gaskets to go between the outside of the boat and the fitting itself. Should I apply any caulking in addition to the fiber gaskets, between the gasket and the hull? If so, what type is recommended?
The thru hole fitting is not an espar, so does not come with a silicone gasket, just the 2 fiber gaskets.
Any suggestions would be appreciated.
Thanks-
Ben
Thanks-
Ben
