Updates: The first photo is "before" at Captain Charlie's:
Then when "Thisaway" arrives at her new home--at least for now on the trailer while I do some work on her. The first 10 days were at the shipyard where the old bottom paint was removed, two more coats of barrier paint were added, and 3 coats of new bottom paint. The entire boat was compounded and heavy wax applied and buffed, and a few minor cosmetic gel coat items were repaired. She looks like a new boat--even no numbers or name.
I had cautioned the workers about the C Dory logo decal--and my friends doing the work who own the "shop" had cautioned the employee--but he hit it with the buffer. As a result a local shop made a new set of C Decals:
Today we put an old RV cover we had over the boat to protect from leaves etc, and I ordered a new full boat mooring cover from Angola Canvas. $813 in Sunbrella and it should be here in 10 to 12 days! Seems like a bargain when compared to local canvas lofts (For precise fit of a camper canvas, I would still go with the local).
The next items are going to be re-routing the depth sounder cable thru the transom below the splash well, and putting in the Starboard for the transducer. Fortunately one of my friends had a nice piece of Starboard he didn't need. I will photo these projects.
After that we will put in the second radio: Standard Horizon GX 2100 (I know that the 2150 is easier to interface the GPS with, but I had purchased the 2100 before the 2150 came out..)
I am moving the mount for the Garmin GPS 440S to allow me to the a mount for a Garmin GPS 541 (which I use on the Caracal). The 440 screen will be divided between sounder and the large area chart. The 541 screen will be close range GPS and AIS. So far we are not opting for Radar, and I have ordered a FLIR First Mate MS224, which makes more sense for us running in our bay where there may be crab pots, debris, or even people in the water, rather than other boats (although we see these occasionally at night). I can envision other uses, including security, finding the black dog at night, hot terminals and other wiring or engine problems, checking for temperature differentials and improving insulation around the house etc. If were were in other areas; Radar would make more sense.
Then we will probably insulate the walls and ceiling of the V berth area, with a vinyl cover over the foam. We have decided not to do an enlargement of the door to the forward cabin, since the boat does not have the sliding "Barber" chair.
Hand rails for the top outer aft and forward have been purchased and will be installed. Gear Hammocks will hang from the ceiling over the V Bert for clothing and gear storage. Probably a set of rod racks will go in the ceiling over the dinette, and an extra LED light with red and white LED's will go over the helm. The anchor light has already been changed out to an LED.
We have not decided to add a 3rd battery and inverter/charger or use a Honda Generator for the stove. I tend to lean toward the Honda, since it can also run the small air conditioner which will work thru the front window.
