Tenders for a 22' Angler
Catch 22
May 1, 2008
385
2004
25 Cruiser
Catch 22
I am looking for a good inflatable that will fit well on the roof our 22" angler. I think 7'-6" long would be ideal. One like Pete has on C-dancer would be ideal but is too expensive for me right now (Alaska Series). Does anyone recommend any particular inflatable 8' or under?
Our Achilles LT2 hauled two people and two dogs back and forth to shore all last year and is still holding up well.
The bottom is much more vulnerable than the Alaska Series, but if you are careful and don't drag it or beach it too hard it's fine. It's made with hypalon as well, as opposed to PVC, which the Alaska Series uses.
My LT2 cost about $800 new, but I think I scored a pretty good deal.
Good luck.
We have used a range of blow ups rafts, kayaks, soft and hard floor dinghy. I would go with the best dinghy you can get with a blow up ridge floor. They are the easiest to row and stay a little dryer. If you don't have a doggy to get to shore I would go with a hard kayak or two. You just need a recreational kayak. You can get one for under $300 at walmart or cableas. You will be able to not only go ashore but explore your area and see more wildlife while in a anchorage.
Bombard have the Max 1 on special at $699. Google it and order online. Just a bit bigger (wider) than my AX 1 on Nomad.
Martin.
West Marine has their slat floor PRU - 3 roll up for $700. This is an excellent dingy (although it is PVC--with Hypalon being better if you are gong to leave it exposed to the sun. This boat is 8'6" with 17" tubes, and is a good craft. We had one, and gave it away when we sold our first C Dory 22. (Kept a smaller one--and although it served us well, it was a bit on the tight side. at 6'7"
I have a lot of admiration for the Achillies boats, and believe that they are some of the best made today. But the LT2 is a "doughnut"--that is it has a soft round transom. There are advantages to this, but it does give you a slightly smaller inside usable area. Also 13" tubes vs the 17" tubes for the West. if you get a chance, compare with the LT4--a foot longer and with 15" tubes…. both good boats, and a lot depends on your needs and personal sizes. There are some other good boats made in Korea. Be careful about the 'no name brands" out of China.
Wow Kevin, I had the perfect tender for sale a couple of weeks ago cheap. It was only used 1 season and in good condition. No one responded so we gave it to Caryns brother. Sorry buddy.
Can you share your plans for its use?
ferry supplies and pets?
one person or several
oars or need an OB?
I'll echo the recommendations for Achilles. Have owned several brands over the years, including 3 Achilles, and they are all excellent quality. My LSI-96 (now called the LSI-290) is still like new after 12 years of frequent summer use. Really like the high pressure floors for portability, easily inflates and packs down, no need to store on the roof (my roof is too small for any dinghy).
However, for my Angler 16' the LSI-96 / 290 is admittedly overkill so I'm currently considering a smaller/lighter model such as the 7.5' LSI-230 or the LS2-RU (same as LT2 but with a transom). But I do really enjoy using the larger 9.5' size, it's fast and seaworthy and often goes on long dinghy excursions while leaving the main boat anchored. Have circumnavigated Sucia, gone over to Matia, Patos, Lummi, etc. many times. With 6 hp, it scoots!
Use will be primarily for ship to shore For two poeple and sometimes a small dog. I would like a smaller/ lighter one so Anna and i can getvit off the roof and back up easily. With the shorter cabin on the angler i feel like less tjatc8 feet would be ideal. I have seen a lot at 8'-6" wich would work
Depending on how much overhang you can live with, this one could be an option for you as well. http://alpineboats.com/kaboat-crossover ... sk396.html
We use a 14ft model for three of us and it proved popular enough during and after the Friday Harbor event this year that I believe two more C-brats have 12ft versions on the way.
Less than 50lbs and well built for $599. Can also be paddled with a kayak paddle if you don't like oars and you can actually sit on the seats instead of being forced to sit on the side tubes due to lack of space.
We have a shorter roof than you so we added a rack for our 14, but the 12 is so light it could be managed with some overhang on most boats stored upside down or right side up.
I think you have seen the pic of the 12 we had on our 25 and that was a perfect fit.
Greg
