Swim platform
dotnmarty
Active member
Nov 3, 2003
4,209
1
1993
DOR15295C393
LIZZIE II
I want to put a swim platform on so that I can easily flush out the motor while in the slip and change the prop etc. The factory one is listed for about $450! Has anyone had good results with an alternative cheaper one? Thanks
I put the "outboard" model of AFI on the CD 25. Has a nice ladder, works fine. Perhpas a bit more diffucult to bolt in place. I have used this on several boats in the past. The issue may be if there is enough space on the transom for the platform and the motor to turn to each side.
Cost was about $120 wholesale price.
Did you use the teak or the poly? Thanks for your response.
