I made my third attempt to winterize my TomCat. I must admit I'm still more in the learning rather than doing phase.
First, the good news. I finally took the boat out for a short run up the river. Wow! Whisper quiet, smooth as silk and fast as lightning. Very, very cool.
I then tried to install the hot water heater bypass kit. No luck at all. I could not even get the hose disconnected from the existing fitting. I unscrewed the plastic fitting but the hose was still solidly connected to the elbow fitting coming out of the tank. No idea what was going on there so I screwed it back together and went off in search of a barrel of antifreeze because temps are supposed to drop into the low 20s in the next couple of days.
West Marine had no antifreeze in stock. AutoZone had a ton of bad attitude but apparently no antifreeze. Walmart had 486,387 customers which I think exceeded our state's COVID limit of 30% occupancy so I didn't even bother going in.
Three gallons was going to have to do it. I emptied the tank as best I could, including draining the hot water tank. Poured in most of the three gallons and ran the sink faucet until it appeared to be not water - but not really pink either. Pured some in the head (pumped the holding tank dry last week - but see below), put some down the shower drain and splashed a bit in the fishboxes.
Then I went searching for the bilges. Shouldn't be hard to find but with me you just never know. I found a cavernous space reachable through and hatch in the space under the table. As I am not an octopus, I was unable to squirm around enough to see what was in that space but it appeared to be bone dry so I left it alone.
I then looked across the companionway, under the sink in search of the same type space. If it's there, it's well hidden under a screwed down panel. I did, however, see a switch for Pumpout and Macerator. How that switch works, I have no idea. It certainly didn't just turn. I have a picture but the C Brats help says there should be an "Add an attachment form" at the bottom of this page - and I can't find that either. (I did figure out how to add the pic to my album)
All of this got me thinking - are there schematics available for the TomCat? The previous owner left a very nice notebook containing manuals for all the various bits of equipment but I did not see an owners manual or anything directly from C Dory. I recall this being an issue on my previous C Dorys as well - evne the 16 that I bought new.
I now have a very general idea of where most stuff is in the boat but a schematic would be very useful. For instance, I really don't know where the bilge pumps are - assuming there are bilge pumps. Bunch of other stuff I would like to know as well. For instance, do the fish boxes simply drain overboard? (And if they do, why oh why didn't they make the drains flush instead of raised?)
Lots to learn. Hope nothing freezes before I learn what I need to know.
