John S-
Good product, but I'm trying to visualize someone trying to mix the two parts in a bucket or whatever's handy and get it into the hull's hole quickly.
Maybe they ought to make it in paired bags with a breakable barrier in between so that it could be quickly mixed with your hands and shoved into the hole before you're working in your "new submarine"?
An outer bag with some fabric strength would also help in getting it placed and stuck in the hole. The fabric ought to be somewhat porous to allow the epoxy to bond to the fiberglass hull.
Would be kinda like a big porous beanbag with an epoxy Bondo Bomb inside.
Could be housed in an outer plastic Zip-Lock bag for the mixing stage that could be removed for placement into the offending hole.
Another avenue would be to make it like Plumber's Epoxy Putty with inner and outer concentric layers, though that stuff is a bit stiff and would take some real hand strength to mix a large amount of.
Maybe what we need is a big ball of water-activated epoxy that's stiff enough to be shoved into a hole and will automatically harden in a fairly short period.
Too bad the insulation foam that comes in canisters isn't stiff enough to stay in place under water pressure.
I suspect there are plastics that could do this job out of a two-part canister set -up with some R&D. The market would also be there for an effective life/boat saver. Witness the price of the first mentioned kit at $325 or so.
Fun to think about!
Joe. :teeth :thup
Fun to think about!
Joe. :teeth :thup
