Recommendations for bottom paint shop?
tcr_pnw
Looking to slip the Venture 23 for the summer and need to get the bottom painted. I live in the Marysville area. Any recommendations for a good shop Seattle to Bellingham friendly to C-Brats? I'd prefer Everett to Mount Vernon if possible but willing to drive. Was quoted $1500 and thought that was quite steep.
Also, thoughts on Pettit's Vivid for a trailerable option?
Thanks in advance,
Troy
At Les's recommendation I had my Tomcat done at Cap Sante Marine in Ancortes. The bottom needed two coats as the old stuff was getting quite thin. The used Interlux CSC micro ablative paint (compatible with the previous stuff). Total quote/cost for the paint was $1200 not including tax. Give them a call at 360-293-3732.
I have used Petit Vivid on 3 boats now. The Caracal has been owned for 4 years, and had a 30 mil epoxy job first and 2 to 3 layers (on the sides) of Vivid. It was kept on the lift (or trailer) and in the water 50/50. This winter we had it in the water in the keys for 2 months, and there was some growth, easily removed with a pressure washer. However after 4 years, the bottom job does not owe me anything!
So for a trailerable, I certainly would recommend the Vivid.
this in on the list to do this summer. at that price i would look at doing it myself. how much of the old bottom pain needs to be removed before a new application? and one last question what to do if you have no clue what kind of bottom paint is on there? it is at least 15 years old...
Thanks for the leads and feedback everybody!
When I looked at getting a Trophy done a while back I was quoted $25 a foot on the hull. The Venture shot through the roof because it was stated the flat bottom was tough to get to and would need a sling or lift. I see their point, but not at that cost.
Also, thanks for the heads up on the Vivid. If there are any other experiences with them I'd like to hear it.
Have a great Memorial Day weekend!
If the old bottom paint is hard and in good condition (not flaking) then you can go with any type of paint. If it is soft, then you have to go with soft paint. I would stick with the soft paints, if you are trailering. If the paint is 15 years old, and in good shape, than you should be able to put a soft paint right over it, with minimal sanding. Be sure it is clean--no oils or greases.
