Ferg":3momigzz said:
Thanks Bob. I do have WiFi on the boat, do you know of the options expand with that available? .......I kept on plugging and found what seems to be a nice one from Rage Cams. I'll need to hard wire it to my Garmin Chartplotter, but this looks like it will do the trick
How do you have wifi on the boat? (12 volt router, connected to your MFD, various transducers & instruments, or connected to some external wi fi source, which can be continuously used away from the dock?
The reason I suggested the License Plate Rear View camera was because of its 180 degree view, being designed to simply connect to smart phone or pad, and needing only a simple 12 volt source.
To hard wire to the Garmin, you will have to have one with the Video input,one of the 7xxx, or 8xxx series, or one of the very latest (not yet approved) 722, 1022/1042 etc...(more in this same series). I would be cautious of cracking the case if you don't have a Garmin with the video input. Garmin has a special reverse image marine camera: GC 10--which has the limitations above.
There are a number of devices which have internal batteries such as Garmin cameras, as well as similar cameras to the GO Pro--some are waterproofed and in portable cases or for portable use, as well as fixed use. But the batteries have to be recharged, and that is a disadvantage.
If you are gong to hard wire, there are any number of great back up cameras. My son has one with a 7" monitor for his 25. I used one of these on the top of the cabin of my 25 when I was towing it behind the RV--and ran a cable from the camera, thru a plug at the trailer hitch, under the RV to a 7" screen on the dash of the RV--a great safety feature when towing. The same set up would have worked great as a rear view camera on the boat, if I put the screen on the boat.
