Rare C-Dory
For sale is a very rare, restored 1984 C-Dory longhouse cruiser/fishing boat with a Volvo turbocharged inboard diesel engine mated to a Volvo Duo-prop stern drive. This is the only diesel-powered C-Dory for sale at present, and one of the (very) few ever made. The boat has extremely low hours (343 on the original engine clock at present) and shows it, as it is overall in very good condition. Outstanding fuel economy and reliability.
This boat is about 98% of the way through a systematic rebuild. . ..a few minor jobs (final hull buff, interior floor paint, etc.) remain--and will be completed soon--but the boat is operable and ready to be shown/test ridden at any time.
History: Boat was custom ordered through C-Dory in Kent, WA by original owner in 1983 and immediately outfitted with a full hydraulic downrigger system and set up as a coastal fishing boat. It was used for several short seasons off the southern Californian coast before being laid up on the hard due to owner's health issues. Boat sat for many years in the inland dry desert air, not being taken out but only having the engine started from time to time. Boat was purchased this past year by current owner, moved back to the Puget Sound area and restored--and is now for sale.
Layout: V-berth forward, with marine head under port side cushion. Storage under v-berth and starboard side cushion. Main cabin is next, with large table that converts to double bed to port, inside steering station to starboard, and small galley behind steering. Good storage under all seats and in drawers. Full "Alaskan bulkhead" and closable door at rear of main cabin. On the back deck there are 2 very large fish/storage holds in the floor immediately behind the bulkhead door. Fuel tank is under the floor behind the fish boxes, and finally the engine compartment/bilge/hydraulic pump area is in the very rear of boat.
Hull: High quality balsa-cored sandwich construction. . ..no "2 by 4" stringers or cheap plywood anywhere in this boat! Hull and deck in overall very good condition for age. No signs of any groundings, damage, blisters, delamination, transom cracks or other structural issues. Bottom is clean and smooth, and has 2 factory-installed external longitudinal ribs to stiffen this longer-than-normal C-dory hull. New stainless steel thru-hulls installed for head inlet and outlet. Some small dings and spider cracks in the gel coat here and there, but overall glass is very good condition. Gel-coat has been completely wet-sanded, buffed and waxed back to great condition. Green trim accents. Hull measure 27' long by 8' wide.
Cabin: C-Dory made 3 versions of this boat: a "short" a "long" and an "extra long" house...this is the medium-sized "long house" model. Big enough for some living comforts , but not too large to compromise the massive rear deck space. Cabin in good condition overall. Old sealant between cabin and deckhouse was removed, cleaned out, and replaced with 3M 5200. Some small dings and spider cracks in the gel coat here and there, but overall glass is very good condition. Windows all original and in good condition. Nice radar arch on cabin top.
Rear deck: Water-shedding, arced balsa-cored deck was been repainted with grey KIWI-GRIP non-skid paint. This paint is long lasting and very easy to repair. . .simply repaint. Deck is very large (compared to a C-dory 22) and very strong. . .no signs of any degradation.
Engine (Volvo AQAD30-A): Original 1984 4-cylinder turbocharged 110 H.P. motor. Engine has been fully reworked: new gaskets, seals, oils, belts, filters, cables, breather, etc. to bring it into good operating condition. Original 311 hours on the clock. Engine starts easily and runs fine, with no sign of overheating, leaks or other issues. All engine panel lights and all gauges work fine. Bilge below engine is very clean. . .no signs of oil, water or coolant leaks. . ..dry and sound.
Sterndrive: (Volvo 280 DP): Drive reconditioned with new oil, bellows, clamps, grease, shaft-lube, water inlet fitting and pipe, shift cable and gaskets. Old oil was clean with no signs of metal shavings or water intrusion. Steering helmet is tight with very little lateral play. Extra set of OEM duo-props (2) in excellent condition included in sale.
Fuel system: Original leaking aluminum fuel tank removed from boat, repaired (re-welded), and also fully encapsulated in epoxy/3 layers of 10-ounce fiberglass cloth as an extra preventative measure. Will outlast boat at this point. 2 new fuel senders and gauge at helm, new supply and return hoses, new grounding wires. New Racor 10 micron filter. 100 gallon total capacity in tank (2 50 gallon halves).
Steering: New Teleflex hydraulic helm pump installed at main inside steering station. New Teleflex stern drive steering cylinder installed. System has zero leaks or issues and works perfectly. Outside (bulkhead) steering station left out as new owner may want to convert boat back to "cruiser" with no second steering station...but that station can be easily be put back in as the hydraulic lines and fittings are still in the boat and are ready to hook up.
Bulkhead: Old worn-out plywood bulkhead/door completely removed and replaced with brand new UV stabilized "Starboard" composite (plastic) material. New hinges and new Perko keyed lock on door.
Glass: Original windows all in good condition, no cracks or leaks. Original rubber exterior molding was pulled and replaced with sealant. New smoked Plexiglas installed on the front opening deck hatch.
Exterior woodwork: All original teak parts, including handholds and rear deck rails removed and replaced with 1" "Starboard" composite plastic.
Interior woodwork: Original plywood sanded out and refinished with several coats of teak oil.
Upholstery: Original blue upholstery in older but good condition. No odor or serious stains. All upholstery removed from boat and professionally cleaned, and stored in a heated indoor location over the wetter winter months.
Galley: New pump faucet installed that draws from small water tank under cabinet into round stainless sink. New plumbing lines to tank and overboard fitting. New ORIGO electric/alcohol stove near rear door. Several drawers and a shelf for storage.
Electrical system: All wiring checked and updated where needed. 2 new DYNO batteries. New 2-way battery switch. New BLUE SEA SYSTEMS 12 volt panel installed.
Electronics: Minimal, new owner will need to install based on needs. Checked and updated where needed. Icom VHF radio works fine. . .new external VHF antenna with new cabling installed.
Fish holds: 2 massive (100 gallon capacity each) fish holds. Large deck lids are easy to remove and offer good access.
Head: New Jabsco marine head, Y-valve, and all new hoses installed. New Y-valve, directs waste into 15 gallon tank or overboard. Head, tank and hoses are all unused.
Hydraulic gurdy system: Well thought out system that works fine. Includes reservoir tank, main pump, stainless lines and 2 Pacific King drive motors. 2 movable gantries swing outside for fishing/stabilizing and inside for running. 2 custom boat stabilizers and 2 lead balls included. Hydraulic system can be left as is or removed to convert to cruiser.
Trailer: Dual axle Calkins trailer. Trailer appears to be rebuilt with a mix of newer and older parts. . .so. . .some of it is in excellent shape and other parts are older. Can be used as is (the driver who deliver boat up the west coast said it ran fine and straight all the way up the west coast) or refurbished. Tires near new. All lights work. Tabs current and legal.
Both boat and trailer have clear, clean title (no bank liens) and are ready to go. Asking price is $35,000 USD.
•do NOT contact me with unsolicited services or offers
Before the listing is gone, here are the specs to save for future reference but didnt save the pics
Joe
Can you save them to your album?
Thanks a million
bb
Almost , This is the long cab mine is the extra long cabin. The difference is that this boat has the head under the v-berth on the right side ( ?? ) . My head is at the rear of the cabin across from a closet. The under deck storage is also configured different.
I think this would be a great cruising fishing boat for someone. I would love to test drive it some time.
Tom,
Would twin 115s on a bracket be reasonable power for this? (Just read about the new Yamaha 115 -- lighter weight and more HP.
This boat looked so familiar and it hit me....
http://www.c-brats.com/viewtopic.php?t=18757
This boat is identical to the one in California we discussed in 2012. It's so similar I thought it was the exact boat, but the one in Alaska is missing the rear controls.
The diesel is somewhat appealing, but not being a big fan of inboard/outboard drives, I would want to repower with a transom bracket and big single outboard.
I think this is the same boat we saw which sold for $16000 in 2012. The current owner took out the aft station, put in a new bulkhead/ door, and rewelded/glassed the fuel tank. (Which was suspect in 2012. The current owner has done some other upgrades.
Also Similar to "Great Republic" Also if you didn't have the need for the he aft deck it would also be a great boat for conversion to a Extra Long House--with a full shower and enclosed head etc. The problem is that a 110 hp diesel is going to give you semi displacement speeds at the best. I agree it would be interesting to run the boat as it is, and see what sort of speed you obtain. I would bet on 10 to 12 knots. Another possibility is to put in a Newer Volvo 200+ hp or Yanmar 200+ HP Diesel…(Not sure if that outdrive would handle the torque, but it should)
This boat was in So Cal for a while. Not sure if it is the same one. (The second steer station could have been added later.
I agree, not a fan of the I/O drive, and especially the bellows.
Your right Bob, its the same boat.
modules.php
This photo from Chrismorris's album shows some traction tape(?) on the surface of the berth below the cushions, and its the same in the craigslist ad.
I think this boat is seriously cool! It is the same one we saw awhile back--I recognize the steering wheel, I remember it came from an old car--surely one of a kind. It would be a great project. Be a fine boat when all back together. I'd lengthen the cabin to get the head and closet like Tom's. Wish I could have afforded it then or now. Can't have two boats and my 22 is also a seriously cool boat and useable right now!!
Joe or somebody it would be great to have a record of this boat. As Brent said "for future reference". Doing this is way above my skill level!!
Ooohh, I bet you that Petersburg boat would clean up nicely. I really like the lines and the Yamahas hanging on the stern. Me likey! :thup
Thanks Bill.
Thanks Bill.
Likewise, Like it with OB power.
