Phil Barnes
I have a CD 22 with an injected Honda 90 running a Honda Solas 13.5 inch diameter X 15 pitch aluminum 3 blade prop. This is the standard prop and what most folks start with. It works but I think it can be fine tuned maybe. When heavily loaded for cruising I can achieve about 5200 rpm. The WOT range for the injected 90 is 5300 to 6300 rpm so I am at the lower end of the range. When very lightly loaded on calm water it will run up to about 6000 rpm or a bit more and about 28/29 mph. I would like to get a little more toward the middle of the rpm range when loaded and looked at changing to a Honda Solas 13.75 diam X 13 pitch 3 blade, which is the next step down in that line of props.
A Brat running the 13 pitch prop posted in another thread that he was hitting 6300 rpm (may have had the governor working limiting the rpm to 6300?), 23 mph WOT and burning about 7.5 gph at WOT. I don't have any specifics on load for that example or for cruising speed in the lean burn range of less than say 4100 rpm. I think this prop may drop my fuel mileage more than I would like. A 2 inch drop in pitch should increase rpm about 400 rpm theoretically (one inch of pitch generally increases rpm by about 200 rpm, but there are other factors that depend on engine, boat, load etc. ).
Marc at Weifingers Marine had posted some time ago that he recommends the stainless Mercury Vengeance (or Quicksilver Verado - same prop different badging I believe) at 13.375 diam X 14 pitch 3 blade for the Honda 90. At least two other Brats also run this prop for heavy loads and reported in other threads that it works well for them. 12-14 mph at 3800 rpm rising to 16-17 mph at 4000 to 4100 rpm as the load lightens (there may have been a comment about as the ice melts and the beer supply is consumed).
Another Brat runs a 4 blade prop at 13.75 inch X 15 inch pitch. I didn't find specifics on that example. I have read that changing to a 4 blade prop of the same size and pitch drops rpm similar to adding one inch of pitch (about 200 rpm). I don't know if that plays out in practice or not.
I am very interested in hearing what props folks are running on heavily loaded CD 22 cruising boats with a 90 hp (carb or injected). Particularly interested at speeds in the lean burn range, say less than 4100 rpm as well as WOT rpm and WOT speed when fully loaded. Any info on fuel mileage is always helpful.
There are several other threads that go into detail on prop design, prop theory and adjustment for altitude (Lake Powell etc.). Rather than repeating that info here I was hoping for on the water experience for fully loaded CDs set up for a long cruise.
Thanks in advance!
Thanks in advance!
