OK... The good, the bad, and the ugly.....
It was August and 97 degrees. I had an entire week I could spend on Lake Martin. I had a brain fa....burp. Why not just build me a stand like TVs sit on in briefing rooms, and let the cheap $100 5,000 AC window unit blow in from the aft windows. Spent about $10 on 1x3 pine for this "proto-type-let's just try it" set up.
It worked great. ZERO holes drilled in the boat. Mounts/dismounts in 10 minutes, 5 of which is just putting on a bit of duct tape...BUT....do put it in the port aft window....cause when you go to back into a slip you can not see backwards without leaning over into the aisle and looking out the door....but, if you get lucky as I did... you slip the boat right inbetween a 35' and 40+' Sea Ray/Maximum..... toss a rope and go on in for dinner.
IT IS UGLY. IT WAS AND ENDED up being used just as was... but, I proved my point, and had a blast in the 97+ degree heat with 85+ % humidity.....
Now once you stop laughing at the red-neck-back porch set up...you have to realize that once rafted up with several 30+' boats....of the design mentioned above.... the kids loved MY BOAT!!! They could close the cabin door, turn on the raw water wash down...spray each other and everything in sight down to the max...have a blast....and not get hollerd at for getting the $riken boat wet.... You have to love a real boat.
End plan was to rebuild the stand, or at least cover the stand with bead-board, painting it white as to match the boat. Have a "top" section that simply folded down when the AC was in use from the 3 exposed sides. This added me a place to store the 2nd size "Big Green Egg" in the lower portion, along with a place to hang ropes, and store other little things that we always need to stow. Without drilling holes was accomplished by using bungee cords that were attached to the aft bulkhead by the earlier installed "rope hooks?" that were also bungee material.
Step 1: Put the stand next to the wall and bungee it to the wall.
Step 2: Place the AC on the stand and run the power cord thru the open window, to the plug behind the helm seat.
Step 3: Add the grey foam stuff used when mounting the AC unit in a home window for a good seal around the window.
Step 4: Use a bit of duct tape for a good seal.
Step 5: Plug her in and watch the humidity leave and the temp drop.
Yes... in our climate it produced a bunch of condinsation. I simply taped a very small funnel to the aft edge corner allowing the "pan" of the AC to maintain the water needed for cooling the unit itself, and the drain off ran down to the funnel, and out a small clear plastic tube routed down the under edge of the gunnel shelves, and down to the scuppers.
The AC this year is still working...but in a shed now...
What I liked about it was:
1: IT WORKED.
2: I did not have to screw around each day/night putting it in/out.
3: It mounted/dismounted in less than 15 minutes (after initial learning curve/try outs) as to allow me to trailer the boat, or for the winter months.
4: For less than $150 (figuring if I had bought a sheet of bead-board and hinges/clasp, and quart of paint/primer)... I had AC that could be used while on the trailer, or in the boat.
5: I no longer had to worry about the $riken little bugs that can/do get thru the screens that are the perfect size to restrict air flow, but only give our insects down here a play ground and landing zone to rest a bit on before coming on into the boat and bitting the shinola out of you all night.
6: GREAT SLEEEEEEEEEEEPING.
BYRDMAN :thup
Chill My Fellow C-Brats.... :beer :beer :smiled [/img]
