Well-known member
- Joined
- Nov 2, 2003
- Messages
- 21,775
- Reaction score
- 126
- C Dory Year
- 2007
- C Dory Model
- 25 Cruiser
- Hull Identification Number
- DOR25652A707
- Vessel Name
- thataway
Rich,
Manufactures do not have any control on how products are used/abused. Thus many will deny warantee with after market accessories. I have never let this influence my decision to use something like a Permatrim.
I have no idea what you mean by a "level trim (you later use the word Neurtal trim and imply that some of use choose to buy a boat which has inferior running characteristics) boat". Each boat will run at a certain attitude , and can be influenced by the trim of an outboard or I/O. Inboards do not have this luxary. In many boats trim tabs and foils will give the boat a better ride. The C dory is one of these boats. This does not indicate a poor design. I am quite sure that there are certain conditions. where trim tabs and a Permatrim would improve the ride of your boat.
High dead rise boats will require much more HP than a low dead rise boat There are always l tradew off in boat design.
Yes there are a number of fins out there--and I have used several different ones. But Permatrims seem to work the best for a C Dory. My current boat has a Doel Fin, and I feel that a Permatim would improve its running.
Ventillation and cavitation are two different animals--and should not be mixed. Vetillation is air or gas sucked down around the prop blades. This causes excessive slipage of the prop. Cavitation is where there is a low pressure formed behind the prop blades. When this reaches a critical pressure, the bubbles form. These can cause physical damage to the surface of a prop.
