C-Wolfe
Member
- Joined
- Sep 16, 2020
- Messages
- 383
- Reaction score
- 16
- Location
- Anchorage
- C Dory Year
- 2008
- C Dory Model
- 255 Tomcat
- Vessel Name
- Valhalla
thataway":1ozuyy7p said:There are a number of slightly different products which are "Meguiares marine wax," (Paste, Cleaner Wax, liquid "M5616 Marine/RV Pure Wax Carnauba Blend", the list goes on--and I have probably tried 90% of them. Meguiares wax product go on easily and are easily buffed out.
There is more work with the Collinite 885, but it lasts longer.
What machine and what product are you using to "buff" and "polish"?
You can get acceptable--and what looks good, with a minimal effort. The problem is it does not last. If you start out with the heavy duty compounding, then a lighter compounding, polish and then good quality wax, which you never allow to complete deteriorate , the entire system will keep the boat looking good, and protect the gel coat for years. If you go for a lessor job, then you end up repeating the lesser procedure many times over.
There are so many products--and systems--whcih probably can make one very confused. Generally sticking with one system or several of the well known marine products-such as by 3M is best.
For the best compounding one goes to the heavy duty machines--such as the Makita 9237CX3 7", The DEWALT 7-Inch/9-Inch (DWP849X), There is the use of either wool or foam pads--different pads for the various stages of compounding to get a good base for the wax system. The importance is a compounding machine which does not bog down as you vary the pressure. A cheap Harbor Freight or Northern Tools, is a fraction of the cost, but just does not keep the same RPM if you put pressure on it. A circular machine to start with and the final steps with a Random Orbital machine. I have found out that a good right angle battery operated drill with a 2 to 3" foam pad works for the smaller areas such as near decals, and decks, work well on the C Dorys.
Here is a video on using the rotary buffer This person has a series of videos on how to get a quality job on compounding, polishing and waxing. While in the mood for watching, check out his other videos on polishing waxing the second machine (random orbital) etc.
Also sort of the "rage" is ceramic coating. Si02 is a cheaper variant, and may not last as long. There are the cheap DIY materials, to the professional applied which can run into the hundreds of dollars for the top of the line--which lasts several years.
There are a number of systems by: 3M, McKee's 37/Nautical one, Chemical Guys, Shurhold, Presta,Smoovewax, Starbrite, (My experience is that the Meguiar's system is just not as durable, even though it may give a good look initially.) I would suggest using one system and staying with it. Wax the boat on a regular basis--if left in the water then perhaps 2 to 3 times a year. If kept under cover--then you may only have to do a good wax job every few years. The secret is to never allow the hull to begin chalking and keep wax on the entire hull.
As I understand it, the Collinite 885 is a bit harder to use but will last longer, will it be ok to wax the boat hull with Colonite 885 over a different brand(Meguiar's paste wax in my case) that was apply on the previous year?
