Sea Wolf":3hb96wbf said:
I've owned mine since '98, and have not found any manufacturing or structural flaws yet, which speaks for the quality of these 1987-1990 models.
Just curious what changed in 1991?
One other note on the boats up to around sometime in the early 90's (not sure when this changed, but sometime after 1990) is that the window frames are a bit different. Cosmetically, they are silver (aluminum colored) vs. white. Functionally, the two big side windows don't have the added track that has the sliding screen in it, if that's something that matters to you. There is also a "larger" rubber molding piece on the outside that can deteriorate, but some people have found new ones that will fit in its place. It's just something I noticed when I looked at a 1990 boat and then researched the windows while I was considering that boat.
But basically, I'd say it's just a long series of minor changes (from 1987 through the current day). Some of them may be improvements to you, and some may not be. Mostly it's a matter of taste. My main feeling is that with a used boat (presuming the basic design is what you want) it's
all about condition. The older the boat, the more chances its had to either be maintained superbly, half-heartedly, or not at all (or somewhere in between).
When I was shopping I looked at quite a few 22's, from many different years, and I didn't notice any fundamentally better or worse built boats. What I did notice is three things:
1) Condition
2) How the boat was rigged and outfitted (gear, engine, electrical, etc.)
3) Which set of evolving detail changes I liked vs. which ones I preferred an older/different detail (this covers many things, from the cockpit sole, to the interior cabinetry, to the cockpit side pockets, and on and on). I don't know that I could say across the board that any were "best," but more just individual preference.
I found the early 2000's to be my "sweet spot" in terms of feature changes that I liked. But I looked at a 2009 and would likely have bought it if it hadn't been a high top (I wanted a regular top). There were some "improvements" by 2009 that I didn't care for; but then there were also some improvements that I did like (detail/features, not basic build). I also looked at a 1990 that I would happily have bought except for a couple of "non-build" (outfitting) and condition things I didn't care for. But the basic boat would have suited me just fine.
As to your question about what has changed (from 1988 to the present), it's not the basic hull or cabin shape, and I can't think of any major "structural" changes (just a few minor ones); but there have been a LOT of "detail" changes over the years, so it would be a huge post to try to list them all. There are threads that contain a good bit of this information, if you were to search for them (things like "changes years" or something like that). My feeling is - as noted above - that whether or not one likes these changes is a matter of personal taste. I can't really think of anything that has made the boat better in an absolute sense. My guess is that most owners would find many of these detail changes they like in their boat; but if they had a magic wand they might change some of them to details from other years. Just personal taste. Like maybe someone likes the fixed/raised cockpit sole that came in around 2007, but they might like the larger cockpit side storage compartments from earlier boats. Or maybe they like the raised lip fiberglass lazarettes from the mid-90's, but then they like the fiberglass interior furniture that started in the late 2000's. Or they just buy the boat that comes up when they are looking, is in the condition they want, and go with whatever mix of features it has. That's likely most common.
