n a nutshell, the original model, introduced in 1979 was called a "Hunky Dory". The name didn't go over well with the public, so the manufacturer wanted to change the name to "Sea Dory". That name was already in use, so they changed it to "C-Dory".
The original manufacturer was Marben Marine, and there are still some original "Hunky Dorys" around, including at least one that belongs to this site.
"As to checking with moisture meters, are you all referring to checking the fiberglass for moisture? Rarely get a long enough dry spell to do that and I currently do not have dry storage. But if I could, would I be checking the bottom gel coat with a moisture meter ? Remove paint first?"
thataway":3g8op7j0 said:Here is a quote from Joe in 2005:
