The Lori-L finally has a new aluminum anchor winch attached to the front deck. Took me most of 3 weeks working an hour or so a day to cut it out and build the drum for it. Used 5052 1/4 inch aluminum for the main structure and drum circles and 2 1/2 aluminum pipe for the center. Tacked it all together and had Rozema Boat works out in Bayview do the welding part because I don't do aluminum. The Dory had 135 feet of 3/8 rode on it already, so I extended it another 50 feet and added 18 feet of 1/4 galvanized chain to the Danforth and it still would hold another 50 I'm sure. I would rather have used 1/2 but 3/8 for this size boat will most likely work for the places we will be anchoring. Had 1/2 on both our 35 footers and the 40 in Alaska and never lost an anchor, so the 3/8 should be fine. I'm driving the winch with one of those $50.00 2000 lb 12 volt anchor winch motors attached to the starboard side directly to the drum side plates. I cut the 2000 lb aluminum winch drum in half and used them on both sides of the drum to support and drive it. I don't know how to put photos on here, but it actually turned out OK. If someone wants to tackle one I could easily email you photos of the work stages in progress. I looked for a small aluminum winch on Ebay but they were too expensive for my blood ($1300-$3000). I had made a couple hydraulic ones for our commercial boats out of aluminum and they worked fine, so I figured I would try a smaller version with 12 volt. Takes about 3 minutes to spool on the length I have but after the spool gets about half full, it speeds up considerably. Most of our anchoring will be in 15 to 20 feet of water, so won't be getting clear down to the spool anyway. (unless we get into a blow). Right now I have about $175 in it not counting several hours of my labor which I guess is not worth much anymore. I have a lathe and did use it for part of it, but it could also be done with a hole saw. They are really not that bad to build once you get it all laid out. I just cut everything out with my table saw and thin 7 inch carbide blade. Trued the drum on my lathe and it was ready for the welder.. Sure beats hand lining an anchor.
