I do the same thing as you with the plastic spools Roger. I use electric wire spools, and if you get the right ones, they work pretty good. I found a size that holds 400 feet of 5/16 lead line. I use all lead line and they are not that heavy. I could see why you would only want to use a few feet of lead and some poly or whatever, but I use all 5/16 on my shrimp and crab pots both. On my crab spool, I use 4 75 foot lines on the same spool and just fasten the ends and continue on until I have all 4 on. It is kind of a pain to find a good storage spot on the Dory with it's limited back deck space, but if you use 1" galvanized water pipe and the mounts for it, it gets you by. you could stack 3 on the pipe and one mounted to the "T" that you use to crank the line onto. I use a 1/2 PVC pipe base flange and screw it into the side of the spool and thread a short piece of 1/2 PVC into it for a crank handle. Just transfer the handle to each spool. I use an ACE electric line hauler and the wife spools the line on as I bring them up. I have only been using 2 shrimp pots lately because if you get in the right spot, you get most of 2 limits in the first pot anyway. I'm talking spots. If you went with a single aluminum that would hold 1600 feet, it would be pretty big but probably manageable. I bought a 1600 foot spool at the Everett boat show a few years back and had to carry it back to the truck and it got pretty heavy by the time I got to the truck. I fished an 18 tri-hull for years and with it's open bow, I had a good place to haul the pots & spools. I just bought this C-Dory a short time ago and have been trying to get it set up to fish, crab, and shrimp the same basic way the tri-hull was. I have found out that I probably should have went for a 25 instead of the 22 though. A little more deck space would really been great, but I kinda like the 22, so will have to make it work. I realize the 22 is primarily a little cruiser, but I am trying to make it work for the best of two worlds. I'm only about 20 minutes north of you if you want to take a look at my setup or if I can help with anything.. It would only take a couple hours to make something that would work for the line you are using. It would be big, but doable I think.
