dan.kelly14":3u9ir6wp said:
:idea Great looking stove! but I was planning to use it to heat the cabin during the day if its cold & use a elect. heater at night with my honda 1000
"sea wolf " liked idea for your gen. from your pics. It does not sound like you think I should use propane in the cabin though for heat.
Where did you buy your beach ladder, I NEED ONE! looks great.
GREAT SITE YOU GUYS HAVE, LOTS OF HELP AND IDEAS!!! :thup
Dan-
People DO use propane heaters (like the Mr. Buddy) heater during the day, but they must be very careful about ventilation, having a cracked window or two always open!
Carbon monoxide (CO) poisioning is cumulative and insidious!
The carbon monoxide molecules attach to the hemoglobin in your red blood cells that carry oxygen into and carbon dioxide out of your body cells, rendering the cells incapable of supplying oxygen to your body. This can happen quickly or very slowly, but occurs like an anesthetic, putting you to sleep without you becoming conscious that it's happening. You just drift off to sleep, permanently!
Ventilation must be very good, and there is always some danger when using any heater or stove that does not have an exhaust pipe externally vented to the outside of the cabin.
You can use a Carbon Monoxide Detector in the cabin to monitor the carbon monoxide levels, but according to Dr. Bob, only a few detectors intended originally for aviation use in airplanes are sensitive enough to protect against cumulative low-level exposure over longer periods. These aviation type detectors cost as much or more than an externally vented heater, making their use with an inexpensive heater not cost-effective. Also, all CO detectors have a 3-4 year useful life and must be replaced and tested periodically.
The Honda 1000i generator and electric heater is a safer combination, but even then, carbon monoxide poisioning is an ever present danger. Having the generator on the rear of the boat (down on the swimstep is best) with the boat facing into the wind, such as at anchor, is the best with a window cracked again for positive ventilation. At a dock, the wind can shift and blow fumes into the cabin, but it's also possible to move the generator further away from the boat with an extension cord.
If it sounds like I'm being extra cautious here, it's because I, nor anyone else, wants to be responsible for a casual recommendation that costs someone else his or her life!
The ladder on the front of my boat is just a standard
under platform telescoping one for swim platforms from Windline with 3 steps. Makes it possible for old guys like me to get off and back on the boat on a beach or trailer.
Windline UP-3X Ladder
